Sorry Pete, local Blynk Server on NAS don´t work on my installation. I need a turotial which is working and don´t stop the Blynk Server on NAS.
On Raspberry Pi Zero W the local Blynk Server is working.
Thank you for your comment.
Mike
@buemo please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Pete,
I was very frustrated that the local Blynk Server on Synology NAS was not running. The Sign in in the admin tool was not possible. After many days and hours I stopped installation and handicraft work and deleted the installation.
I installed a Raspberry Pi Zero W with local Blynk Server with the information from Petes Website on github. Some problems must be cleared with “googleing”.
The sketch which was running on Blynk Cloud did not run on local Blynk Server. So some changes in the sketch were nessesary.
Today all is working fine and I will start in the next days build sketches for ESP8266 and ESP32 to run on local Blynk Server.
Mike
In my opinion, the preferred solution:
