I have deleted all files in dic Blynk and have new installed from your page
When I log in via SSH I get these results:
DS220@DS220:/volume1/Blynk$ java -version
openjdk version “1.8.0_275”
and then I get these result:
/volume1/Blynk$ java -jar server-0.41.16-java8.jar -dataFolder logs
Error starting Blynk server. Stopping.
The directory /Blynk/logs is their
What’s the rest of this message?
Is the /Blynk/logs path valid, and does it have write permissions for all users?
What happens if you don’t specify the -dataFolder ?
The way you presented the data made it appear that “ The directory /Blynk/logs is their” was part of the error message. It seems that it wasn’t, and it’s a comment added by you, which should have read “The directory /Blynk/logs is there”, meaning that the /Blynk/logs folder exists.
Pete,
I have stopped to install Blynk Server on Synology NAS!
Now I have tried to install local Blynk Server on Raspberry Pi Zero W:
Something is wrong on your tutorial:
You wrote:
and next
<java -jar server-0.41.15-java8.jar -dataFolder /home/pi/Blynk
it must be ... 0.41.16-java8.jar ....
Please have a look on my terminal messages:
pi@raspberrypi:~ $ java -jar server-0.41.15-java8.jar -dataFolder /home/pi/Blynk
Error: Unable to access jarfile server-0.41.15-java8.jar
pi@raspberrypi:~ $ ls
pi@raspberrypi:~ $ java -jar server-0.41.16-java8.jar -dataFolder /home/pi/Blynk
Blynk Server successfully started.
All server output is stored in folder '/home/pi/logs' file.
Admin password not specified. Random password generated.
Your Admin url is https://127.0.1.1:9443/admin
Your Admin login email is admin@blynk.cc
Your Admin password is d.....a>
wget "https://github.com/Peterkn2001/blynk-server/releases/download/v0.41.16/server-0.41.16-java8.jar"
and in the next tow lines
Run the server on default 'hardware port 8080' and default 'application port 9443' (SSL port)
please compare "v0.41.16" vs. "0.41.15":
This wrong version makes this as result
Pete,
the install on Rasberry Pi Zero W did not work without
“sudo apt update && sudo apt full-upgrade -y” after installation Rasbian 2021-05-07-raspios-buster-armhf-lite.zip
