Load old project into new app
I’m trying to use this project for a solar charging setup. Issue is I cant load the QR code into the new Blynk app for some reason? Sorry completely new here!
Is this even possible?
You won’t be able to load a Legacy app definition into Blynk IoT, the two systems are totally different, and also un-connected.
You’ll need to manually create the app in IoT, along with the corresponding datastreams.
You’ll also need to update the sketch to make it IoT compatible.
Hi Pete,
Thank you do clearing this up.
My background is electronics so this will be a completely new learning process for me, when I have time Ill have another look at it.
Thanks you again for your advise.
Ben
