Little help LCD widgets + DHT22
hello, wondering a little help on my project for garden irrigation, wondering aid in the visualization of temperature and humidity on the LCD display widget, I have a esp8266 + DHT22 + mousture sensor, someone is kind enough to show me the string to display the temperature and the humidity? precise that the soil moisture sensor value works, thanks in advance
#define MOISTURE A0
#include <DHT.h>
#define DHTPIN 12
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
int moisture= A0;
int value= A0;
    char auth[] = "xxxxxxxxxxxxxxxxxx";
 WidgetLCD lcd(V7);
void sendData(){
delay(300);
      int enableZone1 = LOW;
      int timerZone1 = LOW;
      int manualZone1 = LOW;
      int enableZone2 = LOW;
      int timerZone2 = LOW;
      int manualZone2 = LOW;
      Blynk.begin(auth, "xxxxxxx", "xxxxxx");
      timer.setInterval(500L, manageZone1);
      timer.setInterval(500L, manageZone2);
      pinMode(moisture, INPUT);
      pinMode(2, OUTPUT); // Zone 1
      digitalWrite(2, HIGH);
      pinMode(5, OUTPUT); // Zone 2
      digitalWrite(5, HIGH);
    //  Zone 1
    BLYNK_WRITE(0)
    { enableZone1 = param.asInt(); }
    BLYNK_WRITE(1)
    { timerZone1 = param.asInt(); }
    BLYNK_WRITE(2)
    { manualZone1 = param.asInt(); }
    //  Zone 2
    BLYNK_WRITE(10)
    { enableZone2 = param.asInt(); }
    BLYNK_WRITE(11)
    { timerZone2 = param.asInt(); }
    BLYNK_WRITE(12)
    { manualZone2 = param.asInt(); }
    void loop()   // run over and over again
      value= analogRead(moisture);
      lcd.print(8, 0, value);
    //  manage Sprinkler Zone 1
    void manageZone1()  {
      if  (((enableZone1 == HIGH) && (timerZone1 == HIGH)) || (manualZone1 == HIGH)) {
        digitalWrite(2, LOW);
        Blynk.virtualWrite(8, HIGH);
        lcd.print(4, 1, "Zona 1 ON");}
      else  {
        Blynk.virtualWrite(8, LOW);
        lcd.clear();}
    //  manage Sprinkler Zone 2
    void manageZone2()  {
      if  (((enableZone2 == HIGH) && (timerZone2 == HIGH)) || (manualZone2 == HIGH)) {
        digitalWrite(5, LOW);
        Blynk.virtualWrite(9, HIGH);
        lcd.print(4, 1, "Zona 2 ON");}
      else  {
        Blynk.virtualWrite(9, LOW);
         lcd.clear();}
Hello.
delay should be removed.
lcd.print(8, 0, value) - you can’t do write in a loop.
Please have a look into those simple examples :
LCD push
DHT11
I think you can easily combine both.
hello , I want you to begin to thank you for the timely response and attention that you gave me , ok I proceeded to delete the " delay" function , I see the link you pointed out to me I already managed to create " V pin " and to display the temperature and humidity on " Value display widget " my problem is that I do not know what to put in es . " Lcd.print ( 1 , 1 , ??? ) ; " in order to read the LCD display the temperature and umidity , just wondering what to indicate , thanks again
