Hi, I need to link a digital pin with a virtual Blynk pin. Hi I need to link a digital pin with a virtual Blynk pin. I have an irrigation system, and I need to schedule the hours when it turns on. Sorry if my English is bad, I’m using a translator. I tried with this code
pinMode(2, OUTPUT); // Initialise digital pin 2 as an output pin
BLYNK_WRITE(V0) // Executes when the value of virtual pin 0 changes
if(param.asInt() == 1)
// execute this code if the switch widget is now ON
digitalWrite(2,HIGH); // Set digital pin 2 HIGH
// execute this code if the switch widget is now OFF
digitalWrite(2,LOW); // Set digital pin 2 LOW
but it does not work for me.
