As stated, it is not stalling out nearly as bad as before I changed the #define BLYNK_MSG_LIMIT 0 to zero… so at 10ms I am pushing a steady 200 Blynk commands a second (confirmed with a counter)… so perhaps I am just hitting the top limit for my setup?
I have been spending so much time testing stuff on my ESP32 (darn that thing is fast ) … so I needed to try this “fix” on an ESP8266 with a scaled down version of the vRGB matrix I am running on my ESP32 (and processing 200 Blynk commands a second).
However, I am NOT seeing any improvement? The best I can get before seeing void loop slowdown is 10 commands a second (1 Blynk.setProperty() on a 100ms timer) … and this is with the CPU running at 160Mhz and half the background processes of the ESP32 sketch
@vshymanskyy is this BLYNK_MSG_LIMIT 0 the correct way to disable this throttling or not?
Yes, it is. You can always check if a particular piece of code gets compiled by inserting #error "Compiles" directive there.
if it fails to compile - it means the code gets compiled. Then you can remove #error
