I have a project that had run stably for a long time but suddenly the LCD widget began to disconnect from its virtual pin (mentioned elsewhere), and now the LEDs don’t light at all. I don’t see the LED issue mentioned elsewhere. Suggestions?
@mnw there seems to have been several widgets that have stopped working in recent days. Please provide details of your system and how you are connecting to Blynk.
I had a problem with led’s and found out the changed how the work( you can turn them on,off and dim them!) this might help you https://github.com/blynkkk/blynk-library/blob/master/examples/Widgets/LED/LED.ino
LEDs had old bug that was fixed. See docs on how it should work now.
Regarding LCD. You are using iOS, right? Could you post your code?
Thanks Dmitriy. I modified the LED code as you suggested and the LEDs are working again. I’m curious - what kind of applications do you envision for variable brightness of the LEDs?
By the way, I love your product, and thank you for your great support.
To answer your question - yes, I’m using iOS.
Regarding the LCD disconnect problem… I simply followed the code in your example sketch and it worked great up until this week. It still works fine when it’s connected - it’s just that it forgets the virtual pin assignment whenever blynk is restarted, and I have to go in each time and edit the widget to re-assign the pin.
The relevant lines of code are…
WidgetLCD lcd(2);
lcd.clear();
lcd.print(0, 0, sanibel.weather);
lcd.print(0, 1, precipString);
I don’t know. You tell me
This one is fixed. Release is on Apple review.
One question about this change: I used to be able to declare:
Blynk.virtualWrite(V15, motorState);
To get an LED that read out the state of my motor (on/off)
I tried
WidgetLED motorLED(V15); motorLED.setValue(motorState);
but that doesn’t seem to work. Does Blynk not interpret HIGH == 255?
Thanks,
JR
No. LED widget values are between 0 and 255. However you can use led.on() for HIGH value instead of led.setValue
Yeah, I ended up going with
if (motorState == LOW){
motorLED.off();
if (motorState == HIGH){
motorLED.on();
It's just a lot clunkier than a single line `Blynk.virtualWrite(V15, motorState);` that I used to use. I'll live :)
Well, if that critical, you may go with little trick :
motorLED.setValue(255 * motorState);
You might say it’s “one weird trick to turn on your LED widget with one line of code” ![]()
