The LED widget should provide the option to center the label. In general I believe it should provide the option to adjust the font size and justification of the label.
Regards,
Roger
Regards,
Roger
Yes, that is what I mean but when I go into the widget there is no setting, just label and datastream
Regards,
Roger
IPhone.
The image you are showing appears to be from the older version of Blynk. Or am I missing something.
Regards,
Roger
No. It’s the latest version of the Android app.
You can use a labeled value widget or text widget as a workaround, something like this:
The iOS LED widget does allow leading spaces to be inserted in the label name, so you can create a centred effect.
Spaces work but I hope that this isn’t the final fix for justification. I also hope font size is included in the future.
Thanks and Regards,
Roger
