I am using a virtual LED on the mobile app to set colour according to certain condition.
Data stream type is set as “string” in the web console.
And now in the mobile app, after placing the virtual LED on to the dashboard, the data stream that we setup will not appear. Unless i change the data stream type to integer or double. As soon as i change the type, then mobile app starts showing the data stream. After selecting the data stream, if i go back to the web console and change it back to “string” the led starts to show colours.
I checked it many times and this repeats every time.
I force closed the app and re-opened but still the issue exists. Even logged out and logged in again in the app n web console.
This issue i faced was on IOS.
The os and app are both up to date.
Then why does the colour does not change when i set the data stream type to integer or double ? As soon as i change it to”string” it starts to display the correct colour.
