Hi everyone
I apologize Madhukesh I’m just trying to solve the problem by trying, I thought that writing in the “blynk 2.0” to someone in the forum had had the same problem and could suggest something. I try to be clearer. I am using the new blynk.edgent and in the example the developers have inserted the part of code called “Indicator.h” which makes a led blink when blynk joins the wifi network. I am trying to figure out how to make the led stop blinking once blynk is connected, below is the code that should do this. I ask the moderators a favor if it is not the right section to ask for this information to suggest me where I should go.
Below is the code where the flashing led should be
#if defined(BOARD_LED_PIN_WS2812)
#include <Adafruit_NeoPixel.h> // Library: https://github.com/adafruit/Adafruit_NeoPixel
Adafruit_NeoPixel rgb = Adafruit_NeoPixel(1, BOARD_LED_PIN_WS2812, NEO_GRB + NEO_KHZ800);
#endif
void indicator_run();
#if !defined(BOARD_LED_BRIGHTNESS)
#define BOARD_LED_BRIGHTNESS 255
#endif
#if defined(BOARD_LED_PIN_WS2812) || defined(BOARD_LED_PIN_R)
#define BOARD_LED_IS_RGB
#endif
#define DIMM(x) ((x)*(BOARD_LED_BRIGHTNESS)/255)
#define RGB(r,g,b) (DIMM(r) << 16 | DIMM(g) << 8 | DIMM(b) << 0)
class Indicator {
public:
enum Colors {
COLOR_BLACK = RGB(0x00, 0x00, 0x00),
COLOR_WHITE = RGB(0xFF, 0xFF, 0xE7),
COLOR_BLUE = RGB(0x0D, 0x36, 0xFF),
COLOR_BLYNK = RGB(0x2E, 0xFF, 0xB9),
COLOR_RED = RGB(0xFF, 0x10, 0x08),
COLOR_MAGENTA = RGB(0xA7, 0x00, 0xFF),
Indicator() {
m_Counter = 0;
initLED();
uint32_t run() {
State currState = BlynkState::get();
// Reset counter if indicator state changes
if (m_PrevState != currState) {
m_PrevState = currState;
m_Counter = 0;
if (g_buttonPressed) {
if (millis() - g_buttonPressTime > BUTTON_HOLD_TIME_ACTION) { return beatLED(COLOR_WHITE, (int[]){ 100, 100 }); }
if (millis() - g_buttonPressTime > BUTTON_HOLD_TIME_INDICATION) { return waveLED(COLOR_WHITE, 1000); }
switch (currState) {
case MODE_RESET_CONFIG:
case MODE_WAIT_CONFIG: return beatLED(COLOR_MAGENTA, (int[]){ 50, 500 });
case MODE_CONFIGURING: return beatLED(COLOR_WHITE, (int[]){ 200, 200 });
case MODE_CONNECTING_NET: return beatLED(COLOR_BLUE, (int[]){ 50, 500 });
case MODE_CONNECTING_CLOUD: return beatLED(COLOR_BLYNK, (int[]){ 100, 100 });
case MODE_RUNNING: return waveLED(COLOR_WHITE, 5000);
case MODE_OTA_UPGRADE: return beatLED(COLOR_MAGENTA, (int[]){ 50, 50 });
default: return beatLED(COLOR_RED, (int[]){ 80, 100, 80, 1000 } );
protected:
* LED drivers
#if defined(BOARD_LED_PIN_WS2812) // Addressable, NeoPixel RGB LED
void initLED() {
rgb.begin();
setRGB(COLOR_BLACK);
void setRGB(uint32_t color) {
rgb.setPixelColor(0, color);
rgb.show();
#elif defined(BOARD_LED_PIN_R) // Normal RGB LED (common anode or common cathode)
void initLED() {
pinMode(BOARD_LED_PIN_R, OUTPUT);
pinMode(BOARD_LED_PIN_G, OUTPUT);
pinMode(BOARD_LED_PIN_B, OUTPUT);
uint8_t r = (color & 0xFF0000) >> 16;
uint8_t g = (color & 0x00FF00) >> 8;
uint8_t b = (color & 0x0000FF);
#if BOARD_LED_INVERSE
analogWrite(BOARD_LED_PIN_R, BOARD_PWM_MAX - r);
analogWrite(BOARD_LED_PIN_G, BOARD_PWM_MAX - g);
analogWrite(BOARD_LED_PIN_B, BOARD_PWM_MAX - b);
#else
analogWrite(BOARD_LED_PIN_R, r);
analogWrite(BOARD_LED_PIN_G, g);
analogWrite(BOARD_LED_PIN_B, b);
#endif
#elif defined(BOARD_LED_PIN) // Single color LED
void initLED() {
pinMode(BOARD_LED_PIN, OUTPUT);
void setLED(uint32_t color) {
analogWrite(BOARD_LED_PIN, BOARD_PWM_MAX - color);
#else
analogWrite(BOARD_LED_PIN, color);
#endif
#else
#warning Invalid LED configuration.
#endif
* Animations
uint32_t skipLED() {
return 20;
#if defined(BOARD_LED_IS_RGB)
template<typename T>
uint32_t beatLED(uint32_t onColor, const T& beat) {
const uint8_t cnt = sizeof(beat)/sizeof(beat[0]);
setRGB((m_Counter % 2 == 0) ? onColor : (uint32_t)COLOR_BLACK);
uint32_t next = beat[m_Counter % cnt];
m_Counter = (m_Counter+1) % cnt;
return next;
uint32_t waveLED(uint32_t colorMax, unsigned breathePeriod) {
uint8_t redMax = (colorMax & 0xFF0000) >> 16;
uint8_t greenMax = (colorMax & 0x00FF00) >> 8;
uint8_t blueMax = (colorMax & 0x0000FF);
// Brightness will rise from 0 to 128, then fall back to 0
uint8_t brightness = (m_Counter < 128) ? m_Counter : 255 - m_Counter;
// Multiply our three colors by the brightness:
redMax *= ((float)brightness / 128.0);
greenMax *= ((float)brightness / 128.0);
blueMax *= ((float)brightness / 128.0);
// And turn the LED to that color:
setRGB((redMax << 16) | (greenMax << 8) | blueMax);
// This function relies on the 8-bit, unsigned m_Counter rolling over.
m_Counter = (m_Counter+1) % 256;
return breathePeriod / 256;
#else
uint32_t beatLED(uint32_t, const T& beat) {
setLED((m_Counter % 2 == 0) ? DIMM(BOARD_PWM_MAX) : 0);
return next;
uint32_t waveLED(uint32_t, unsigned breathePeriod) {
setLED(BOARD_PWM_MAX * (DIMM((float)brightness) / (BOARD_PWM_MAX/2)));
#endif
private:
uint8_t m_Counter;
State m_PrevState;
Indicator indicator;
* Animation timers
#if defined(USE_TICKER)
#include <Ticker.h>
Ticker blinker;
void indicator_run() {
uint32_t returnTime = indicator.run();
if (returnTime) {
blinker.attach_ms(returnTime, indicator_run);
void indicator_init() {
blinker.attach_ms(100, indicator_run);
#elif defined(USE_TIMER_ONE)
#include <TimerOne.h>
if (returnTime) {
Timer1.initialize(returnTime*1000);
Timer1.initialize(100*1000);
Timer1.attachInterrupt(indicator_run);
#elif defined(USE_TIMER_THREE)
#include <TimerThree.h>
if (returnTime) {
Timer3.initialize(returnTime*1000);
Timer3.initialize(100*1000);
Timer3.attachInterrupt(indicator_run);
#else
#warning LED indicator needs a functional timer!
void indicator_run() {}
void indicator_init() {}
#endif
thank you
Best Regards
