[LED COLOR FAIL] With Widget Device Selector
In my project, The widget LED works fine (on/off & change color property) if it’s linked directly to a device.
But if it’s linked to the widget device selector, the color property doesn’t work anymore.
I think there is a bug in that case.
Could you check please?
Thanks for this report, we will fix it in the next release, I guess it would be tomorrow.
Is this the same issue that I’m seeing with a Widget LED being triggered by Eventor? I can see the white crescent appear and disappear when Eventor activates and deactivates the LED, but there is no color displayed.
This is a year old topic… many changes since.
If you have an existing topic on this, then please keep commentary in there, if not, then please create one.
Although I suspect that you are simply sending a value that sets the intensity of the color to a very low value…AKA 1, when the range is from 0-255.
See here… different device but possibly same issue.
Thank you.
