Hi all, i’m using the node.js library for blynk but i can’t find example how to push value from the raspberry pi 3 to the virtual LCD pin in blynk…
Someone have an example?
No one?
Can’t you just use the lcd.write function like for the Arduino?
Does i need to install a specific node module?
You have to use the WidgetLCD. Example:
var v3 = new blynk.WidgetLCD(3); //LCD on virtual pin 3
v3.clear(); //clears LCD
v3.print(0,0,‘Test’); //prints on LCD
@tulo Please take note of the TimeDate stamps… this topic is well over a year old
But I guess your js answer is better late then never
