LCD widget has strange label that can't be edited
I’m using an LCD display, and am having an issue in that it displays a strange label at the bottom (see screenshot).
I can’t seen to change the label using the setProperty command.
Blynk.setProperty(V6, "label", "Status");
I’m running Blynk v 1.3.0 on an ESP8266, using a mobile device with iOS v 16.6.
Thanks in advance!
It’s not changeable. It says something like “Blynk Electronics” in Chinese and it’s a little joke by Blynk that goes with their documnetion for the widget that says…
LCD
This is a regular 16x2 LCD display made in our secret facility in China
Thanks for your response. I suppose I’d be more amused if I weren’t using a paid version.
Any thoughts as to why the label doesn’t work? Or is that an inside joke as well?
@Pavlo FYI
Because the Chinese text isn’t a label, so can’t be changed via the setProperty(vPin, “label”, value) command.
I get it, but I was taking the documentation at face value.
I suppose I should abandon this widget in favor of something less silly, and not believe everything I read in the documentation.
https://docs.blynk.io/en/blynk.apps/widgets-displays/lcd
@bdubs we’ll look a it during the upcoming weeks.
This looks like a discrepancy in the documentation, but let’s wait and see if we can improve the widget in this aspect.
Sorry for confusion
Thanks.
First of all, nobody said that this is a changeable label… Labels changeable by setProperty are usually editable in widget settings and located in the upper part of the container.
Try the formatted text widget or a combination of 2 any other labels (if you need 2 strings) - stay creative!
