LCD widget and device selector issues
I am using a sketch with device selector.
All widgets work when choosing device but LCD widget wont show anything. I have to stop the sketch and select the device manually. Then it works correctly.
Is this a bug?
What device are you using? On Android or IOs? Also could you attach here screenshot of the LCD settings?
On Android.
Here are the settings.
Are you using blynk cloud or a local server?
Blynk Cloud. Both devices are Particle Photons.
Ok, we’ll check this issue on our side. Thanks,
Hello.
How is this matter going forward?
I also have this problem with the LCD widget.
It would be great if the “tag” function should be also available!
Any updates regarding this issue?
This issue will be fixed in the next release.
Do we have any news on the LCD widget to show correctly when using Device Selector?
To give you an example of what happens:
When selecting a different device, 1st line shows old data from previous device and 2nd line shows new data from selected device.
It was fixed on Android. Do you have iOS?
No, I am on Android 7.0 Samsung S6
