LCD Is not working without WIFI
lcd is not working.
it works only after connecting to the wifi network and I would like the lcd to work independently
#define BLYNK_TEMPLATE_ID "xxx"
#define BLYNK_DEVICE_NAME "xxx"
#define BLYNK_AUTH_TOKEN "xxx"
#include <Wire.h>
#include <OneWire.h>
#include <Timers.h>
#define D1 5
#define D2 4
#define D3 0
#define treconnect 30
float tempC = 0;
int liczreconnect = 10;
char ssid[] = "xxx";
char pass[] = "xxx";
LiquidCrystal_I2C lcd(0x27, 20, 4);
OneWire oneWire(0);
Timers <3> akcja;
int stanLED_ok=0;
int LED;
lcd.backlight();
sensors.begin();
lcd.init();
lcd.clear();
Serial.println(LED);
//Blynk.syncAll();
float TEMP1 = sensors.getTempCByIndex(0);
float TEMP2 = sensors.getTempCByIndex(1);
float TEMP3 = sensors.getTempCByIndex(2);
float TEMP4 = sensors.getTempCByIndex(3);
lcd.setCursor(0, 0);
lcd.print("TEMP1");
lcd.setCursor (9, 0);
lcd.print(sensors.getTempCByIndex(0));
lcd.print((char)223);
lcd.print("C");
lcd.setCursor(0,1);
lcd.print("TEMP2");
lcd.setCursor (9, 1);
lcd.print(sensors.getTempCByIndex(1));
lcd.print("C");
lcd.setCursor(0,2);
lcd.print("TEMP3");
lcd.setCursor (9, 2);
lcd.print(sensors.getTempCByIndex(2));
lcd.print("C");
lcd.setCursor(0,3);
lcd.print("TEMP4");
lcd.setCursor (9, 3);
lcd.print(sensors.getTempCByIndex(3));
lcd.print("C");
Blynk.virtualWrite(V1, TEMP1);
Blynk.virtualWrite(V2, TEMP2);
Blynk.virtualWrite(V3, TEMP3);
Blynk.virtualWrite(V4, TEMP4);
delay(30);
Please edit your post and add triple backticks ( ``` ) before and after your whole sketch.
First of all, both blynk.begin and blynk.run are blocking functions, so internet connection is required.
Second thing, you should read this
https://docs.blynk.io/en/legacy-platform/legacy-articles/keep-your-void-loop-clean
Old Blynk works no problem but connecting was
Blynk.config(auth, "blynk-cloud.com", 8442);
Blynk.connect();
if (Blynk.connected()) Blynk.run(); else Blynk.connect();
lcd.backlight();
sensors.begin();
lcd.init();
lcd.clear();
timer.setInterval(1000L, temp);
but I cant’ connect to new blynk in the same code. So have to put
Blynk-cloud.com is the old blynk server, the new blynk server is blynk.cloud
also, Blynk uses 443 port for TLS connections and 80 port for plain connections
doesn’t work
other connection option?
Have you tried Blynk.config(auth); ?
Maybe if you shared your code it would help.
Are you manually configuring your WiFi connection first?
Blynk.config and Blynk.connect do work with Blynk IoT, I’ve tried it myself.
It works
Thank you very much for your help !!
Please share the solved code if possible.
@Kamran the hardware that @zkz is using is a NodeMCU. As a said to you in a different topic, your life would be much easier if you were also using a NodeMCU or ESP32.
When you use an Arduino + ESP-01 which is functioning as a WiFi modem in AT mode then you have very limited control over your WiFi system.
Hello again.
Another problem. I need to use wifi.manager to manual connect to WIFI.
And it’s the same problem. LCD only works when connected to wifi.
Is it possible to make a code to work lcd with temperature without connecting to wifi?
Yes.
But as you aren’t telling us what changes you made to add WiFi manager to your existing sketch, or even shared you working sketch prior to adding-in WiFi Manager, its impossible to explain how to do this in your case.
BTW, have you looked at Blynk Edgent as an alternative to WiFi Manager?
code.
My dream is.
“Put ssid and pass, and if Wi-Fi is not connected, make AP - Wi-Fi manager… but LCD must work all the time.”
of course only wifi manager is enough
#include <Wire.h>
#include <Timers.h>
#define D1 5
#define D2 4
#define D3 0
float tempC = 0;
//char ssid[] = "xxx";
//char pass[] = "xxx";
OneWire oneWire(0);
Timers <3> akcja;
int stanLED_ok=0;
int LED;
lcd.backlight();
sensors.begin();
lcd.init();
lcd.clear();
      WiFi.mode(WIFI_STA); // explicitly set mode, esp defaults to STA+AP
    // it is a good practice to make sure your code sets wifi mode how you want it.
Blynk.config(auth);
Blynk.connect();
    //WiFiManager, Local intialization. Once its business is done, there is no need to keep it around
    WiFiManager wm;
    // reset settings - wipe stored credentials for testing
    // these are stored by the esp library
    wm.resetSettings();
    // Automatically connect using saved credentials,
    // if connection fails, it starts an access point with the specified name ( "AutoConnectAP"),
    // if empty will auto generate SSID, if password is blank it will be anonymous AP (wm.autoConnect())
    // then goes into a blocking loop awaiting configuration and will return success result
    bool res;
    // res = wm.autoConnect(); // auto generated AP name from chipid
    // res = wm.autoConnect("AutoConnectAP"); // anonymous ap
    res = wm.autoConnect("AutoConnectAP","password"); // password protected ap
    if(!res) {
        Serial.println("Failed to connect");
        // ESP.restart();
    else {
        Serial.println("connected...yeey :)");
lcd.print("TEMP1");
lcd.print(" C");
lcd.setCursor(0,1);
lcd.print("TEMP2");
lcd.print(" C");
lcd.setCursor(0,2);
lcd.print("TEMP3");
lcd.print(" C");
lcd.setCursor(0,3);
lcd.print("TEMP4");
lcd.print(" C");
delay(30);
akcja.process(); //timer Timers.h
if (Blynk.connected()) {
Void loop :scream::scream::scream:
And where is your working sketch without WiFi manager?
If that means that only WiFiManager can achieve this for you then you clearly haven’t looked at Blynk Edgent as I suggested.
:rofl::rofl::rofl:
Love the idea of trying to read 4 sensors ever 30ms, and that fact that there a BlynkTimer declared and fed in the void loop, but not used :confused:
#include <Wire.h>
#include <Timers.h>
#define D1 5
#define D2 4
#define D3 0
float tempC = 0;
OneWire oneWire(0);
Timers <3> akcja;
int stanLED_ok=0;
int LED;
lcd.backlight();
sensors.begin();
lcd.init();
lcd.clear();
WiFi.begin(ssid, pass);
Blynk.config(auth);
Blynk.connect();
//Blynk.syncAll();
lcd.print("TEMP1");
lcd.print("C");
lcd.setCursor(0,1);
lcd.print("TEMP2");
lcd.print("C");
lcd.setCursor(0,2);
lcd.print("TEMP3");
lcd.print("C");
lcd.setCursor(0,3);
lcd.print("TEMP4");
lcd.print("C");
delay(30);
and this actually works?
You appear to be missing quite a lot of WiFi connection code that loops in a while or for loop until WiFi.status() != WL_CONNECTED
Your WiFi manager code seems to have abandoned the concept of connecting to WiFi altogether, so I can’t see how it could ever work, unless it’s using the WiFi credentials that the ESP stores in is NVR.
Even when you sort this out, your void loop is appalling and breaks all the rules of Blynk, so your sketch needs some serious restructuring.
I keep asking this, but have you looked at the Blynk Edgent example?
Blynk Edgent - no working :frowning:
