Hello , any one can help me with code for write a massage through text input widget and send it into lcd i2c ?
I using esp , lcd i2c , blynk app .
Thanks .
It will depend on which I2C library you are using, as the syntax varies.
I’d suggest that you choose a library, make a note of where you found it and what version number it is, then use it to get your I2C LCD working and displaying messages without Blynk.
Then share your working code and details of your chosen library and we’ll point you in the right direction.
            Ok , i will doing that , thanks for your help my dear brother
