LCD flickers
Hello
Can you please tell me why in the program the LCD flickers
#include <Fishino.h>
#include <BlynkSimpleFishino.h>
char auth[] = "80a7c4faf7c4258";
WidgetLCD lcd(V0);
WidgetLED led0(V1);
WidgetLED led1(V2);
char ssid[] = "ich";
char pass[] = "98312623";
bool enableTimer = true;
bool enableTimer1 = true;
BLYNK_WRITE(V3)  // Timer enable/disable
  int setting = param.asInt();
  enableTimer = setting;
BLYNK_WRITE(V4)  // Timer enable/disable
  enableTimer1 = setting;
void checkTimer()
  if((enableTimer == 1) && (enableTimer1 == 1))
    // Timer is running, so lights on!
    digitalWrite(6, HIGH);
    led0.on();
      led1.off();
      lcd.print (0,1,"LED ist ON");
    lcd.clear();
    digitalWrite(6, LOW);
    led0.off();
      led1.on();
      lcd.print (0,1,"LED ist OFF");
pinMode(6, OUTPUT);
lcd.print (0,0,"LED ist OFF");
  checkTimer();
1/ you have your checktimer in the main loop
better use blynk timer
2/ in your checktimer you have a lcd.clear.
@markop As you are not new to this forum, you should remember to search this forum for past issues/solutions before posting questions…
Not to mention Google… as this LCD “flickering” issue is exactly the same cause and solution with both the virtual and physical LCD.
http://forum.arduino.cc/index.php?topic=317918.0
I’ve done it a little bit differently so it works without flickering
#include <TimeLib.h>
char auth[] = "58";
WidgetLCD lcd(V0);
WidgetLED led0(V1);
WidgetLED led1(V2);
char pass[] = "3";
void checkTimer()
    led0.on();
      led1.off();
      lcd.print (0,1," LED ist ON ");
   lcd.print (0,0,"LED Notschalter");
    led0.off();
      led1.on();
      lcd.print (0,1," LED ist OFF");
pinMode(6, OUTPUT);
checkTimer();
you will flood Blynk for sure
