LCD Advanced doesn't work with <BlynkSimpleEsp8266.h>?
Got simple LCD to work, but when switching to Advanced, it doesn’t work.
Board is NodeMCU 12E, App on iOS.
Created some test code based on example. Gauge on V6 works well so connected.
I’m getting compile errors when using Ethernet.h and/or BlynkSimpleEthernet.h
Using BlynkSimpleEsp8266.h - Is advanced not included in that library?
Thank you!
Code:
 *   Downloads, docs, tutorials: http://www.blynk.cc
 *   Blynk community:            http://community.blynk.cc
 *   Social networks:            http://www.fb.com/blynkapp
 *                               http://twitter.com/blynk_app
 * Output any data on LCD widget!
 * App project setup:
 *   LCD widget, switch to ADVANCED mode, select pin V1
//#include <Ethernet.h>                <<---- When included, compile errors out on NodeMCU
//#include <BlynkSimpleEthernet.h>     <<---- When included, compile errors out on NodeMCU
#include <ESP8266mDNS.h>
char auth[] = "*****";
const char WiFiAPPSK = “";
const char ssid[] = "
"; // your network SSID (name)
const char pass[] = "
***”; // your network password
WiFiServer server(80);
int i;
WidgetLCD lcd(V1);
initHardware();
connectWiFi(); // Connect to WiFi
setupWiFi();
server.begin();
Blynk.config(auth);
// Blynk.begin(auth);
lcd.clear(); //Use it to clear the LCD Widget
lcd.print(4, 0, “Hello”); // use: (position X: 0-15, position Y: 0-1, “Message you want to print”)
lcd.print(4, 1, “World”);
// Please use timed events when LCD printintg in void loop to avoid sending too many commands
// It will cause a FLOOD Error, and connection will be dropped
Serial.print(“i = “); Serial.print(i); Serial.println(” Hello”);
i = i+1;
if(i>200){
i = 1;
BLYNK_READ(V6){ // Write the Temp
Blynk.virtualWrite(V6, i);
void connectWiFi()
byte ledStatus = LOW;
Serial.println();
Serial.println("Connecting to: " + String(ssid));
WiFi.mode(WIFI_AP_STA); // Set WiFi mode to station and Access Point (as opposed to AP or STA)
WiFi.begin(ssid, pass);
while (WiFi.status() != WL_CONNECTED) // Use the WiFi.status() function to check if the ESP8266 is connected to a WiFi network.
// Blink the LED
delay(100); // Delays allow the ESP8266 to perform critical tasks defined outside of the sketch. These tasks include setting up, and maintaining, a WiFi connection.
Serial.println(“WiFi connected”);
Serial.println("IP address: ");
void setupMDNS()
// Call MDNS.begin() to set up mDNS to point to
// “.local”
if (!MDNS.begin(“thing”))
Serial.println(“Error setting up MDNS responder!”);
while(1) {
Serial.println(“mDNS responder started”);
//////////////////// setup AP ////////////////////////
void setupWiFi()
// Do a little work to get a unique-ish name. Append the
// last two bytes of the MAC (HEX’d) to “ThingDev-”:
uint8_t mac[WL_MAC_ADDR_LENGTH];
WiFi.softAPmacAddress(mac);
String macID = String(mac[WL_MAC_ADDR_LENGTH - 2], HEX) +
String(mac[WL_MAC_ADDR_LENGTH - 1], HEX);
macID.toUpperCase();
String AP_NameString = “HoekBoard” + macID;
char AP_NameChar[AP_NameString.length() + 1];
memset(AP_NameChar, 0, AP_NameString.length() + 1);
for (int i=0; i<AP_NameString.length(); i++)
AP_NameChar[i] = AP_NameString.charAt(i);
WiFi.softAP(AP_NameChar, WiFiAPPSK);
void initHardware()
delay(100);
Never mind - i added a timer and it is working!!
Here is the working code:
char auth[] = "****";
const char WiFiAPPSK[] = "****";
const char ssid[] = "****";                  //  your network SSID (name)
const char pass[] = "****";              // your network password
int i;
WidgetLCD lcd(V1);
  initHardware();
  setupWiFi();
  server.begin();
  Blynk.config(auth);
  timer.setInterval(1000L, sendSeconds);
  lcd.print(4, 0, "Hello"); // use: (position X: 0-15, position Y: 0-1, "Message you want to print")
  lcd.print(4, 1, "World");
Serial.print("i = "); Serial.print(i); Serial.println("   Hello");
i = i+1;
if(i>200){
  i = 1;
void sendSeconds() {
  lcd.print(4, 1, i);
void connectWiFi()
  Serial.println();
    // Blink the LED
void setupMDNS()
  // Call MDNS.begin(<domain>) to set up mDNS to point to
  // "<domain>.local"
  if (!MDNS.begin("thing"))
    Serial.println("Error setting up MDNS responder!");
    while(1) {
  Serial.println("mDNS responder started");
void setupWiFi()
  // last two bytes of the MAC (HEX'd) to "ThingDev-":
  String AP_NameString = "HoekBoard" + macID;
void initHardware()
  delay(100);
@PaulH
Seems your issue resolved. I am new to Blynk and exploring. Does WiFi.mode(WIFI_AP_STA); work with Blynk. Can this be used to extend wifi range?
Thanks,
Suman
This is off-topic and in an old thread. Create a new thread with new questions.
