I wanted to operate a relay with blynk.
I am using a simple code as follow and thereafter made modifications but the problem is that relay got latched while re-connecting to server.
My Hardware is Node MCU D1
and I am using Android.
I am using D2 on android to get signal from Pin2 which results in on off of rela
Button on android is set as 1 -> 0
Sample code as follow:
http://twitter.com/blynk_app
You’ll need:
- Blynk App (download from AppStore or Google Play)
- WeMos D1 board
example.
char auth[] = "5a7b105d4b774c5ab1f6ca2f1c5aecc8";
char ssid[] = "saleem";
char pass[] = "mypass";
int DoorPin = 2;
digitalWrite(DoorPin, HIGH);
BLYNK_CONNECTED() {
Blynk.syncAll();
// to avoid delay() function!
Please let me know how to solve this.
