TTGO 800L
Android
Blynk server
Going through the site i see a hand full of people have experimented with the LWT of the pubSubClient but couldn’t find full implementation. My sketch seeks to determine the exact moment the esp32 powers off so the last will and testament feature would really do it for me. code compiles fine, node-red shows that the client connects to the broker, but no LWT is published when client abruptly disconnects.
// TTGO T-Call pin definitions
#define MODEM_RST 5
#define MODEM_PWKEY 4
#define MODEM_POWER_ON 23
#define MODEM_TX 27
#define MODEM_RX 26
#define I2C_SDA 21
#define I2C_SCL 22
#define BLYNK_HEARTBEAT 30
#define TINY_GSM_MODEM_SIM800
#include <PubSubClient.h>
#include <TinyGsmClient.h>
#include <BlynkSimpleSIM800.h>
#include <Wire.h>
// #include <TinyGsmClient.h>
#include "utilities.h"
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
// Hardware Serial on Mega, Leonardo, Micro
#define SerialAT Serial1
const char apn[] = "gloflat";
const char user[] = "flat";
const char pass[] = "flat";
//Blynk Authentication
const char auth[] = "YKVZxVmxfW6mnNAnW3yHK4X7kX1tP0x-";
// MQTT
byte willQos = 0;
const char* mqtt_server = "192.168.43.220";
const char* mqtt_topic = "fujo/power";
const char* clientID = "powerMonitor";
const char* willTopic = "fujo/power/will";
const char* willMessage = "Power Off";
const char* mqttUser = "admin";
const char* mqttPass = "switchfoot";
TinyGsm modem(SerialAT);
//PubSubClient client(mqtt_server, 1883);
// Set console baud rate
SerialMon.begin(115200);
// Keep power when running from battery
Wire.begin(I2C_SDA, I2C_SCL);
bool isOk = setPowerBoostKeepOn(1);
SerialMon.println(String("IP5306 KeepOn ") + (isOk ? "OK" : "FAIL"));
// Set-up modem reset, enable, power pins
pinMode(MODEM_PWKEY, OUTPUT);
pinMode(MODEM_RST, OUTPUT);
pinMode(MODEM_POWER_ON, OUTPUT);
digitalWrite(MODEM_PWKEY, LOW);
digitalWrite(MODEM_RST, HIGH);
digitalWrite(MODEM_POWER_ON, HIGH);
// Set GSM module baud rate and UART pins
SerialAT.begin(115200, SERIAL_8N1, MODEM_RX, MODEM_TX);
delay(3000);
SerialMon.println("Initializing modem...");
modem.restart();
String modemInfo = modem.getModemInfo();
SerialMon.print("Modem: ");
SerialMon.println(modemInfo);
// Unlock your SIM card with a PIN
//modem.simUnlock("1234");
SerialMon.print("Waiting for network...");
if (!modem.waitForNetwork(240000L)) {
SerialMon.println(" fail");
delay(10000);
return;
SerialMon.println(" OK");
if (modem.isNetworkConnected()) {
SerialMon.println("Network connected");
SerialMon.print(F("Connecting to APN: "));
SerialMon.print(apn);
if (!modem.gprsConnect(apn, user, pass)) {
delay(10000);
return;
boolean rc = client.connect("clientID", willTopic, willQoS, willRetain, willMessage);
// client.connect(clientID, (char*)mqttUser, (char*)mqttPass, willTopic, 0, true, (char*)willMessage);
// if (client.connect(clientID)) {
Serial.println("Connected to MQTT Broker!");
client.publish(mqtt_topic, "Power On");
