HI to all developers
I’m a Beginner in blynk world
I have this code which I tested using the blynk app as well as the physical button on my ESP32 development board and there was a lag or slaw response in turning on and off the relays, please help me if you can by revising such code and to by pass any delays or lag issues
Regards
http://twitter.com/blynk_app
You’ll need:
- Blynk App (download from AppStore or Google Play)
- ESP32 board
example.
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include "settings.h"
#include "secret.h"
#define MQ2 34
void checkPhysicalButton();
int relay1State = HIGH;
int pushButton1State = HIGH;
int relay2State =HIGH;
int pushButton2State = HIGH;
boolean state = false;
int sensorValue = 0;
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
Blynk.syncVirtual(VPIN_BUTTON_1);
Blynk.syncVirtual(VPIN_BUTTON_2);
// Alternatively, you could override server state using:
//Blynk.virtualWrite(VPIN_BUTTON_1, relay1State);
//Blynk.virtualWrite(VPIN_BUTTON_2, relay2State);
//Blynk.virtualWrite(VPIN_BUTTON_3, relay3State);
//Blynk.virtualWrite(VPIN_BUTTON_4, relay4State);
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BUTTON_1) {
relay1State = param.asInt();
digitalWrite(RELAY_PIN_1, relay1State);
digitalWrite(RELAY_PIN_2, relay1State);
delay(2000);
digitalWrite(RELAY_PIN_2, HIGH);
if (digitalRead(PUSH_BUTTON_1) == LOW) {
// pushButton1State is used to avoid sequential toggles
if (pushButton1State != LOW) {
// Toggle Relay state
relay1State = !relay1State;
// Update Button Widget
delay(2000);
pushButton1State = LOW;
char auth[] = "---------";
char ssid[] = "----------";
char pass[] = "----------";
pinMode(RELAY_PIN_1, OUTPUT);
pinMode(PUSH_BUTTON_1, INPUT_PULLUP);
pinMode(RELAY_PIN_2, OUTPUT);
pinMode(MQ2, INPUT);
// Setup a function to be called every 100 ms
timer.setInterval(500L, checkPhysicalButton);
void sendUptime()
sensorValue = analogRead(MQ2);
Blynk.virtualWrite(V1, sensorValue);
Serial.println(sensorValue);
if (sensorValue > 1000)
Blynk.notify("Gas Detected!");
relay1State = HIGH;
// to avoid delay() function!
