It would be nice if we could format large numbers to include commas…
Displaying large numbers would be much more readable if they contained commas…
12393285
vs
12,393,285
Blynk is awesome, thank you for your hard work!
12393285
vs
12,393,285
Since everything sent to a Widget (using virtual pins) is sent as a string, then you can format your long numbers with various conversion codes before sending the result to the widget.
https://www.google.com/search?q=format+long+numbers+into+strings+with+comma+separator+arduino
I should have realized that before I posted
Thanks for pointing it out, that was what I ended up doing…
