I own a Konekt Dash. The now call themselves Hologram,
I have been using Blynk a lot with other Wifi boards and now want to move to the Dash, there is a selection for it in the app but when it comes to using the example for the cloud connection don’t know what one to use or how to connect it,
If someone could provide me what they use that would be great,
The most significant issue I am having is getting it to connect to the blynk cloud,
@Bryson I have just re-checked.
There are several options, depending on what you really need.
You can use Dash + Hologram Cloud, and integrate it with Blynk using HTTP API, IFTTT, Node.RED, or any similar service. Direct connection from Hologram Cloud to Blynk is not possible atm.
If you only need Dash device, it could work with 3rd party SIM in “passthrough” mode. This would be equivalent of an Arduino + 3G modem. Currently we do not support this configuration, but should be doable in theory.
