Hi All,
I need some help understanding whats going on. I can see I am missing a fundamental concept here, any helpful explanations would be appreciated.
I am making a LED Light and I have most of what i want but due to my limited understanding I cannot go further. My LED light is working as intended with Button for RED, GREEN, OFF, BRIGHTNESS, using a slider to light up x many LEDS and Using a Slider to Change Colour. Im super happy with all i have learnt, what i want to add is the Rainbow effect when I click a button.
So what I don’t understand is how can I get blynk to run a loop?
I started with something simple so i can learn.
Adding a button to Turn IT on RED - cool got it
Adding a Butting to turn it on Green - also good etc etc now i want to add a Rainbow effect and I can see the effect is not looping though!? - if I click my button on blynk many many times it will move through the effect slowly. why is it not running / looping that code. Usually you call the function in Void Loop but since its only Blynk.run(); how can I run the rainbow effect?
if I call the Function to the Void Main its run Continuously (thats Expected) how does Blynk control this?
I hope this makes sense. If you can help me understand thank you.
see below details
Hardware model ESP32 Dev Kit V1
communication type. WIFI
Smartphone OS + version 2.26.3
Blynk server
Blynk Library version 0.61
Developer: Kyle Jardine
Created Date: 2020-05-15
Modified Date: 2020-05-25
//Libraries
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include "FastLED.h"
#define NUM_leds 60
#define LED_TYPE WS2812
#define COLOR_ORDER GRB
CRGB leds[NUM_leds];
#define DATA_PIN 2
int data= 255;
int r,g,b;
int BRIGHTNESS = 255;
int POT = 1;
//Blynk
char auth[] = "XX";
char ssid[] = "XX";
char pass[] = "XX";
FastLED.clear();
FastLED.addLeds<LED_TYPE, DATA_PIN, COLOR_ORDER>(leds, NUM_leds).setCorrection(TypicalLEDStrip);
FastLED.setBrightness(BRIGHTNESS);
//FUNCTIONS
void simple_ON (){
//FastLED.clear();
for(int led = 0; led < NUM_leds; led++) {
leds[led] = CRGB::Red;
FastLED.show();
void simple_ON_2 (){
//FastLED.clear();
leds[led] = CRGB::Green;
FastLED.show();
void RUN() { //NUmber of LEDDS
int val = data;
int numLedsToLight = map(val, 0, 1023, 0, NUM_leds);
// First, clear the existing led values
FastLED.clear();
for(int led = 0; led < numLedsToLight; led++) {
//CHange_COLOUR();
leds[led] = CRGB::Blue;
FastLED.show();
//Brightness Function
void BRIGHT(int BRIGHTNESS)
int B = map(BRIGHTNESS, 0, 1023, 0, 255);
FastLED.show();
void Turn_Off() {
//FastLED.clear();
leds[led] = CRGB::Black;
FastLED.show();
void CHange_COLOUR() {
int val1 = data;
int hue = map(val1, 0, 1023, 0, 255);
for (int i = 0; i < NUM_leds; i++) {
leds[i] = CHSV(hue, 255, BRIGHTNESS);
FastLED.show();
void AWESOME() {
//beatsin16 is a function on the FastLED library generating sinwave, (5) is bpm, (0,255) is value range.
//value range will create the breathing effect
uint8_t gHue = 0;
int pos = beatsin16(5,0,192); // generating the sinwave
fill_solid(leds, NUM_leds, CHSV( gHue, 255, pos)); // CHSV (hue, saturation, value);
FastLED.show();
EVERY_N_MILLISECONDS(100) {gHue++;}
// shifting the HUE value by incrementing every millisecond this creates the spectrum wave
//BLYNK DIGITAL INPUTS
BLYNK_WRITE(V1) //read Button value
int V_1 = param.asInt(); // assigning incoming value from pin V1 to a variable
if (V_1 == 1) {
simple_ON() ;
BLYNK_WRITE(V2) //read Button value
int V_2 = param.asInt(); // assigning incoming value from pin V1 to a variable
if (V_2 == 1) {
simple_ON_2() ;
BLYNK_WRITE(V3) //read slider value
data = param.asInt(); // assigning incoming value from pin V2 to a variable
RUN();
BLYNK_WRITE(V4) // Read Button Value for On and off
int V_4 = param.asInt();
if(V_4 == 1){
Turn_Off();
BLYNK_WRITE(V5) //read slider value
BRIGHTNESS = param.asInt(); // assigning incoming value from pin V2 to a variable
BRIGHT(BRIGHTNESS);
BLYNK_WRITE(V6) //read slider value - Change Colour
CHange_COLOUR();
BLYNK_WRITE(V7) // Read Button Value for On and off
int V_7 = param.asInt();
if(V_7 == 1){
AWESOME();
