Joystick with 2 servos
I don’t know how use a Joystick, I mean, I don’t know how can I code that. I used the example of blynk and I saw examples of youtube but it can’t help me. (I’m trying to control 2 servos, 1 with X and the other with Y)
A single joystick will give you 2-axis control, but if you want to split that control acroos 2 joysticks then its quite simple.
Maybe if you start by looking at the Joystick 2 Axis example in the Sketch Builder then ignoring one axis on the first joystick then it will point you in the right direction.
