Hi everyone, I am currently working on a hobby project to create a Wifi controlled drone using the Blynk App. I have stumbled upon a brick wall because the code here stopped working when I call the Blynk.syncVirtual(V20, V21, V22); line. Without initializing the MPU6050, the code worked perfectly fine.
Here are the causes and symptoms:
- When I call the Blynk.syncVirtual(V20, V21, V22) before initializing the MPU6050, the MPU6050 will always fail to initialize.
- When I initialize the MPU6050 first before calling the Blynk.syncVirtual(V20, V21, V22); then the nodeMCU goes into soft reset mode everytime.
Here is what you can safely assume:
- The MPU6050 was tested and working fine on Arduino Uno and NodeMCU (Without the Blynk App)
- the nodeMCU is not broken in any way
- I’ve used the DMP MPU6050 library provided by jrowberg/i2cdevlib
Any suggestion on this matter would be greatly appreciated.
Sketch code:
#include <ESP8266WebServer.h>
#include <Wire.h>
// For MPU-6050
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#include "Wire.h"
#ifndef APSSID
#define APSSID "<USERNAME>"
#define APPSK "<PASSWORD>"
#endif
const char *ssid = APSSID;
const char *password = APPSK;
char auth[] = "<AUTH_TOKEN>";
// Pin declaration
#define SCL D1 //D6
#define SDA D2 //D5
#define INTERRUPT_PIN D5 //D1
/*------------------------------------------------Global Var--------------------------------------------------------*/
ESP8266WebServer server(80);
MPU6050 mpu;
// MPU control/status vars
bool dmpReady = false; // set true if DMP init was successful
volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q; // [w, x, y, z] quaternion container
VectorInt16 aa; // [x, y, z] accel sensor measurements
VectorInt16 aaReal; // [x, y, z] gravity-free accel sensor measurements
VectorInt16 aaWorld; // [x, y, z] world-frame accel sensor measurements
VectorFloat gravity; // [x, y, z] gravity vector
float euler[3]; // [psi, theta, phi] Euler angle container
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
int pitch_roll[] = { 0, 0}; int throttle_yaw[] = { 0, 0};
int pitchVal[] = {0, 0, 0, 0}; int rollVal[] = {0, 0, 0, 0}; int yawVal[] = {0, 0, 0, 0}; int throttleVal[] = {0, 0, 0, 0}; int calibVal[] = {0, 0, 0, 0};
int yawAngle = 0; int pitchAngle = 0; int rollAngle = 0;
pinMode(INTERRUPT_PIN, INPUT);
do {
Wire.begin(SDA, SCL); //Wire.begin (<SDA>,<SCL>)
//Wire.setClock(400000); // 400kHz I2C clock. Comment this line if having compilation difficulties
Serial.println(F("Initializing Gyroscope and Accelerometer..."));
mpu.initialize();
Serial.println(mpu.testConnection() ? F("\tMPU6050 connection successful") : F("\tMPU6050 connection failed"));
Serial.println(F("\tInitializing DMP..."));
devStatus = mpu.dmpInitialize();
// supply your own gyro offsets here, scaled for min sensitivity
mpu.setXGyroOffset(0); // Default 220. Use 0 (value confirmed)
mpu.setYGyroOffset(0 ); // Default 76. Use 0 (value confirmed)
mpu.setZGyroOffset(0); // Default -85. Use 0 (value confirmed)
mpu.setZAccelOffset(1024); // Default 1788. Use 1024 (value confirmed)
delay (1);
while (devStatus != 0);
// make sure it worked (returns 0 if so)
if (devStatus == 0) {
// turn on the DMP, now that it's ready
mpu.setDMPEnabled(true);
// enable Arduino interrupt detection
attachInterrupt(digitalPinToInterrupt(INTERRUPT_PIN), dmpDataReady, RISING);
mpuIntStatus = mpu.getIntStatus();
// set our DMP Ready flag so the main loop() function knows it's okay to use it
dmpReady = true;
// get expected DMP packet size for later comparison
packetSize = mpu.dmpGetFIFOPacketSize();
// ERROR!
// 1 = initial memory load failed
// 2 = DMP configuration updates failed
// (if it's going to break, usually the code will be 1)
Serial.print(F("\tDMP Initialization failed (code "));
Serial.print(devStatus);
Serial.println(F(")"));
Serial.println(F("Gyroscope and Accelerometer --------------------------- OK"));
Blynk.begin(auth, ssid, password); // Connect to Blynk App
// Protection from unintetional disconnect from server. Attempt to reconnect after that.
if (!Blynk.connected()) {
Serial.println ("\nDisconnected from Blynk App");
Serial.println ("Attempting to reconnect...");
delay (1);
Blynk.syncVirtual(V20, V21, V22); // Read all widget values
// Read some Gyroscope values here....
delay (1);
/**********************************************************************************************INTERRUPT DETECTION ROUTINE*********************************
Interrupt pin for MPU6050
void dmpDataReady() {
mpuInterrupt = true;
/**********************************************************************************************************PITCH/ROLL joystick*********************************
Pitch/Roll Joystick
BLYNK_WRITE(V20) {
int x = param[0].asInt();
int y = param[1].asInt();
(y < 384 || y > 640) ? pitch_roll[1] = map(y, 0, 1023, -20, 20) : pitch_roll[1] = 0; // Pitch
(x < 384 || x > 640) ? pitch_roll[2] = map(x, 0, 1023, -20, 20) : pitch_roll[2] = 0; //Roll
/**********************************************************************************************************Throttle/Yaw joystick*********************************
Throttle/Yaw Joystick
BLYNK_WRITE(V21) {
(y > 100) ? throttle_yaw[1] = map(y, 0, 1023, 0, 70) : throttle_yaw[1] = 0; //Throttle. y > 100 to prevent motor burnout under for low PWM values. Default: map(y, 0, 1023, 0, 70)
(x < 312 || x > 712) ? throttle_yaw[2] = map(x, 0, 1023, -35, 35) : throttle_yaw[2] = 0; //Yaw. Default: map(x, 0, 1023, -35, 35)
/**********************************************************************************************************MANUAL RESET*********************************
Reset button on app
BLYNK_WRITE(V22) {
resetVal = param.asInt();
