my project is to monitor home energy using Arduino. I have done the simple blink blynk where I controlled Arduino led to turn off and on using blynk switch with no problem. However, when I added my sketch to display KWH on blynk app I receive this:
"avrdude: ser_open(): can’t open device “\.\COM5”: Access is denied.
#include <EmonLib.h>
#include <Blynk.h>
EnergyMonitor emon1;
#define currCalibration 0.52
float kWh = 0;
unsigned long lastmillis = millis();
char auth[] = "********";
void myTimerEvent() {
emon1.calcVI(20, 2000);
Serial.print("Vrms: ");
Serial.print(emon1.Vrms, 2);
Serial.print("V");
Blynk.virtualWrite(V0, emon1.Vrms);
Serial.print("\tIrms: ");
Serial.print(emon1.Irms, 4);
Serial.print("A");
Blynk.virtualWrite(V1, emon1.Irms);
Serial.print("\tPower: ");
Serial.print(emon1.apparentPower, 4);
Serial.print("W");
Blynk.virtualWrite(V2, emon1.apparentPower);
Serial.print("\tkWh: ");
kWh = kWh + emon1.apparentPower*(millis()-lastmillis)/3600000000.0;
Serial.print(kWh, 4);
Serial.println("kWh");
Blynk.virtualWrite(V3, kWh);
emon1.current(A0, currCalibration); // Current: input pin, calibration.
Blynk.begin(Serial, auth);
timer.setInterval(5000L, myTimerEvent);
Also, no errors when I verify the sketch and I made sure that the correct port is selected from the blynk-sar found in script file.
When I try to open serial monitor, I get the following:
Error opening serial port ‘COM5’. (Port busy)
My guess is there are more than one sketch fighting for the same port but I do not how.
cmd.exe window (always open):
Connecting device at COM5 to blynk-cloudcom:80…
OpenC0C("\.\COM5", baud=9600, data=8, parity=no, stop=1) - OK
Connect(“blynk-cloudcom”, “80”) - OK
InOut() START
DSR is OFF
thank you Pete. ok then is it possible to send sensor data from arduino to Blynk with serial port as my Blynk connection. Ignoring serial.print this time.
Hi again. I edited the sketch but I still get the following :
Problem uploading to board. See for suggestions.
here is my edited code for a reference :
#define BLYNK_PRINT SwSerial
SoftwareSerial SwSerial(11, 12); // RX, TX
#define currCalibration 62
#define Volt 120;
float kWh = 0;
char auth[] = "******";
void myTimerEvent()
float amps = emon1.calcIrms(7400);
float watt = amps * Volt;
kWh = kWh + watt*(millis()-lastmillis)/3600000000.0;
Blynk.virtualWrite(V5, amps);
Blynk.virtualWrite(V6, kWh);
SwSerial.begin(9600);
at this point I think maybe because I was running another sketch on COM5(the only thing plugged to my computer) before I tried to connect to Blynk. I restarted Arduino IDE, and my computer but still same issue.
I’d start by rebooting your PC with nothing plugged into your USB ports or serial ports other than keyboard, mouse etc.
it’s a PC then you need to go to Device Manager and see what COM ports are available, with and without your Arduino plugged-in.
TBH, using this connection method is really only useful as a way of quickly getting up and running with Blynk before you buy some IoT capable hardware such as a NodeMCU or ESP32.
Maybe time to stop wasting time and effort with this and buy some proper hardware.
I’d need to order that. I’m behind schedule, and I really need to view the data on Blynk . I got to upload the sketch to Arduino (upload sketch before opening blynk-ser file) but I ran into another issue where the project on Blynk is offline.
Hi, I have the same problem as you. Is it possible to share your final code again? I tried to change the SwSerial-positions to DebugSerial, but couldn’t solve the problem so far.
Thank you!
