Greetings:
I’m new to blynk currently i’m working on a project with Arduino Uno, I used Esp 01 to connect the Arduino to internet.
I want to display the results on both I2C lcd and lcd widget, but it doesn’t work for some reason
I get connected to Blynk server and a led (on, off) so the ESP is working correctly, then tried to print in lcd widget and it worked ( i got the print on the app) and tried the I2C LCD that i have and it’s working as well.
The problem is when combined both LCD and lcd widget I got the first print on LCD and the widget doesn’t print anything!! And the ESP stay connected to blynk server for seconds (`in blynk app shows that your device is offline).
I couldn’t find out the reason for this conflict, I tried to find which command the conflict starting with, so I deleted every command required for LCD to work then added them one by one, turns out it’s the command to declare the address for LCD.
LiquidCrystal_I2C lcd (0x27, 16, 2).
This is the code
#define BLYNK_TEMPLATE_ID "TEMPLATE_ID "
#define BLYNK_DEVICE_NAME "DEVICE_NAME "
#define BLYNK_AUTH_TOKEN "AUTH_TOKEN "
#include <ESP8266_Lib.h>
char ssid[] = "network_ssid";
char pass[] = "password";
//#define EspSerial Serial1
char dat[] = "hello";
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
// Your ESP8266 baud rate:
#define ESP8266_BAUD 38400
ESP8266 wifi(&EspSerial);
void myTimerEvent()
Blynk.virtualWrite(V5, dat);//millis() / 1000
Blynk.virtualWrite(V0, 58.9); //random to test on blynk app
lcd.print("test");
lcd.begin();
lcd.backlight();
lcd.clear();
lcd.print("test1");
// Set ESP8266 baud rate
and the connection as shown below:
I appreciate any ideas best regards.
