Hello guys im using this code to communicate with the blynk apps via arduino uno and SIM900 but im getting an error and the modem cannot intitialize, i have tried the board to make a normall call to my personal number and its working fine but when it come to connection with blynk its giving me this error.
/* Fill-in your Template ID (only if using Blynk.Cloud) */
#define BLYNK_TEMPLATE_ID "TMPL4N4u5ch6"
#define BLYNK_DEVICE_NAME "MKR1400"
// Arduino MKR GSM 1400 uses U-blox modem
#define TINY_GSM_MODEM_UBLOX
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
char auth[] = "jZX63-SFl_pJUsBObIyQlQFTT4UrybM-";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "vodafone.com.qa";
char user[] = "";
char pass[] = "";
TinyGsm modem(SerialGSM);
pinMode(2, OUTPUT); // Initialise digital pin 2 as an output pin
BLYNK_WRITE(V0) // Executes when the value of virtual pin 0 changes
if(param.asInt() == 1)
// execute this code if the switch widget is now ON
digitalWrite(2,HIGH); // Set digital pin 2 HIGH
// execute this code if the switch widget is now OFF
digitalWrite(2,LOW); // Set digital pin 2 LOW
// Set GSM module baud rate
SerialGSM.begin(115200);
pinMode(GSM_DTR, OUTPUT);
digitalWrite(GSM_DTR, LOW);
delay(5);
// Turn on the GSM module by triggering GSM_RESETN pin
pinMode(GSM_RESETN, OUTPUT);
digitalWrite(GSM_RESETN, HIGH);
delay(100);
digitalWrite(GSM_RESETN, LOW);
modem.restart();
// Unlock your SIM card with a PIN
//modem.simUnlock("1234");
