Just created on GitHub a new ISR-based library enabling you to use 1 Hardware Timer on an ESP32-based board to control 16-or-more independent servo motors.
You can specify which ESP32 hardware timer to use to avoid conflict with other libraries. Default is using timer 3.
It’s quite simple to use.
Here is the sample code
#ifndef ESP32
#error This code is designed to run on ESP32 platform, not Arduino nor ESP8266! Please check your Tools->Board setting.
#endif
#define TIMER_INTERRUPT_DEBUG 1
#define ISR_SERVO_DEBUG 1
// Select different ESP32 timer number (0-3) to avoid conflict
#define USE_ESP32_TIMER_NO 3
#include "ESP32_ISR_Servo.h"
#define PIN_D25 25 // Pin D25 mapped to pin GPIO25/ADC18/DAC1 of ESP32
#define PIN_D26 26 // Pin D26 mapped to pin GPIO26/ADC19/DAC2 of ESP32
// Published values for SG90 servos; adjust if needed
#define MIN_MICROS 800 //544
#define MAX_MICROS 2450
int servoIndex1 = -1;
int servoIndex2 = -1;
Serial.println("\nStarting");
//Select ESP32 timer USE_ESP32_TIMER_NO
ESP32_ISR_Servos.useTimer(USE_ESP32_TIMER_NO);
servoIndex1 = ESP32_ISR_Servos.setupServo(PIN_D25, MIN_MICROS, MAX_MICROS);
servoIndex2 = ESP32_ISR_Servos.setupServo(PIN_D26, MIN_MICROS, MAX_MICROS);
if (servoIndex1 != -1)
Serial.println("Setup Servo1 OK");
Serial.println("Setup Servo1 failed");
if (servoIndex2 != -1)
Serial.println("Setup Servo2 OK");
Serial.println("Setup Servo2 failed");
int position;
if ( ( servoIndex1 != -1) && ( servoIndex2 != -1) )
for (position = 0; position <= 180; position++)
// goes from 0 degrees to 180 degrees
// in steps of 1 degree
if (position %30 == 0)
Serial.println("Servo1 pos = " + String(position) + ", Servo2 pos = " + String(180 - position) );
ESP32_ISR_Servos.setPosition(servoIndex1, position);
ESP32_ISR_Servos.setPosition(servoIndex2, 180 - position);
// waits 30ms for the servo to reach the position
delay(30);
delay(5000);
for (position = 180; position >= 0; position--)
// goes from 180 degrees to 0 degrees
delay(30);
delay(5000);
