So currently I’ve been having an issue with integrating a cancel command into my watering timer. For simplicity my code is just a while loop with the condition that its unlocked and the cancel switch is not activated, and inside the loop i have my pump turn on and then a simple millis timer and pump turn off.
Everything works else works as expected, but when I hit the cancel switch it wont break the loop and stop the pump, I have figured out that the value to cancel the pump is delivering to blynk after the function has ended because I cant water while the cancel switch is on (i intend to make it a button once its working).
Didnt really think code was necessary for this one but lmk if that would be easier.
