Is it possible to write an app similar to Blynk to use with Blynk Local Server?
It’s probably against the terms and conditions of the local server code, and as the local server code base isn’t being updated anymore you’ll run into issues with security vulnerabilities and Java version compatibility.
TBH, if you wanted to write your own app then you’d be better writing your own server-side system too.
