All my projects not connecting to Blynk Cloud
Is there an issue? (My internet is fine, all other connections fine . . .)
cul
billd
cul
billd
It doesn’t look like it:
You can check the status of these three servers here:
https://www.blynk.cc/status
Thnx,
Something going on, exiting connected projects are working fine, but I can’t connect with ant projects I’m working on. Multiple boards having the same issue connect to WiFi OK but cant connect to Blynk Cloud.
Looks like you are still using Port 8442… as mentioned in other topics, that has been changed to 8080 now, so that might be your issue with any projects that reconnect.
8442 should work anyway. This is something else I believe.
Oh, have the rules changed again, or just not yet been implemented in the Cloud? Hard to advise when we don’t know
No changes. Now 8080 should be used. 8442 is still there for back compatibility.
This is not something I’ve ever changed (or even have a clue how to change!), I just use Blynk.begin() and the magic happens . . .
Good… thought I was losing my… oh what is that called again… yes, memory
As shown in the example sketches… you can optionally set a port… I think, eventually, even the cloud will switch to needing 8080 as does Local Server now.
