Can you help me tp resolve this problem in my dimmer project, actually i’m using an ESP8266 ( 3.0.0), when i upload the code to the card, i got this message in the serial monitor :
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
{⸮q⸮⸮i;⸮ISR not in IRAM!
User exception (panic/abort/assert)
Abort called
>>>stack>>>
ctx: cont
sp: 3ffffec0 end: 3fffffc0 offset: 0000
3ffffec0: feefeffe feefeffe feefeffe feefeffe
3ffffed0: 000000fe 00000000 00000000 00000000
3ffffee0: 00000000 00000000 00000000 00ff0000
3ffffef0: 5ffffe00 5ffffe00 00000020 3ffeee44
3fffff00: 00000000 00000002 00000005 4020478e
3fffff10: 40100811 00000100 00002580 402047a0
3fffff20: 3ffefb84 402058fd 00000005 40204ce1
3fffff30: feefeffe 00000001 3ffeed04 3ffeee44
3fffff40: 3fffdad0 00000000 00000005 40204d80
3fffff50: 00000000 feefeffe feefeffe 4020316d
3fffff60: 00002580 0000001c 3ffeea50 402031a5
3fffff70: 3fffdad0 00000000 3ffeed04 40201e60
3fffff80: feefeffe feefeffe feefeffe feefeffe
3fffff90: feefeffe feefeffe feefeffe 3ffeee44
3fffffa0: 3fffdad0 00000000 3ffeee30 402042c8
3fffffb0: feefeffe feefeffe 3ffe85ec 401010cd
<<<stack<<<
I’m new in this field, and i like to learn more about this issue.
Regards.
#include <ESP8266WiFi.h> // Header file for Wifi Module
#include <BlynkSimpleEsp8266.h> // header file for blynk
#include <RBDdimmer.h> // header file for robodyn dimmer
#define auth "ZeBzdsvxb1tzv6zIxYmTyTbpRbYEc0bd" // You should get Auth Token in the Blynk App.
#define ssid "MYLAP" //Enter Wifi Name
#define pass "12345678" //Enter wifi Password
#define outputPin 16 // PWM pin for dimmer
#define zerocross 5 // for boards with CHANGEBLE input pins
dimmerLamp dimmer(outputPin, zerocross); //initialase port for dimmer for ESP8266, ESP32, Arduino due boards
int outVal = 0; // Intialisation value for dimmer
int dim_val; // dimmer value to dim the appliance
Serial.begin(9600); // begin serial communication
dimmer.begin(NORMAL_MODE, ON); //dimmer initialisation: name.begin(MODE, STATE)
Blynk.begin(auth, ssid, pass); // begin blynk server
Blynk.run(); // Run blynk server
BLYNK_WRITE(V0) { // Set to your virtual pin
outVal = param.asInt(); // Get State of Virtual Button
dim_val = map(outVal, 0, 1023, 0, 100); // mapped the value for dimmer
dimmer.setPower(dim_val); // Set dimmer power
Blynk.virtualWrite(V1, dim_val); //sending to Blynk
