Hi guys, timer function (widget) is not run on i phone. Can you test it?
I don’t believe that there’s a problem with the Timer widget on iOS, but before you’ll get any of the developers to look at the issue you’ll have to provide more data.
When you started this new thread it was populated with proforma data you should provide. This included the following:
• Blynk Library version
• Add your sketch code. Code should be formatted as example below.
You should also provide screenshots of the timer widget setup in your app.
