Maybe try this tutorial by a smart kid?
Thanksā¦ that seems a nice description but it doesnāt work on the Mac. I canāt get the blynk-ser.sh script to run in terminal. And it is quite unclear where to find the port number and paste it.
Could you explain what do you do step by step and post what output you get?
Maybe record a video of the process?
Do you have Socat installed?
We would really like to help, but itās hard to do online
Oh, you can join our slack channel for a live communication. If there will be someone at that moment. If itās something you would like - please pm me your email
when i try to run .blynk-ser.sh
I keep getting permissions denied
Peters-Mac-mini-i7:scripts Dalglish$ cd ~/Documents/Arduino/libraries/blynk-library-0.3.1/scripts/
Peters-Mac-mini-i7:scripts Dalglish$ ls
README.md blynk blynk-ser.bat blynk-ser.sh blynk_ctrl.py certs com2tcp.exe gateway.py
Peters-Mac-mini-i7:scripts Dalglish$ ./blynk-ser.sh
-bash: ./blynk-ser.sh: Permission denied
should i move to a different place or re-install?
You need just to run it with āsudoā
sudo ./blynk-ser.sh
Or grant right for script execution to yourself.
in response - thanks for your help
Peters-Mac-mini-i7:~ Dalglish$ cd ~/Documents/Arduino/libraries/blynk-library-0.3.1/scripts
Peters-Mac-mini-i7:scripts Dalglish$ sudo ./blynk-ser.sh
Password:
sudo: ./blynk-ser.sh: command not found
Please try āsudo blynk-ser.shā maybe it will help.
Peters-Mac-mini-i7:scripts Dalglish$ sudo blynk-ser.sh
Password:
sudo: blynk-ser.sh: command not found
Ok letās try another option. When you are in scripts folder execute :
chmod 777 blynk-ser.sh
./blynk-ser.sh
Peters-Mac-mini-i7:scripts Dalglish$ chmod 777 blynk-ser.sh
[ Press Ctrl+C to exit ]
This script uses socat utility, but could not find it.
Try installing it using this guide: http://www.xappsoftware.com/wordpress/2013/10/10/how-to-run-socat-on-mac-os-x/
This is correct. Please follow instructions.
I placed download into the same āscriptsā folder
Peters-Mac-mini-i7:scripts Dalglish$ socat-2.0.0-b9.tar.gz
-bash: socat-2.0.0-b9.tar.gz: command not found
You need to untar (unzip) the file. Is 7z.zip or similar available for those Apple type devices?
Peters-Mac-mini-i7:scripts Dalglish$ cd socat-2.0.0-b9
Peters-Mac-mini-i7:socat-2.0.0-b9 Dalglish$
then what do i run?
Hope you son appreciates all you are trying to do for him.
You might need to chmod 777 socat but then you are back to the original Blynk script. Because you have already done the chmod on the script it is just:
./blynk-ser.sh
Donāt forget the leading fullstop.
i seeā¦ i run
./configure
make
su
make install
Peters-Mac-mini-i7:socat-2.0.0-b9 Dalglish$ ./configure
checking which defines needed for makedependā¦
checking for a BSD-compatible installā¦ /usr/bin/install -c
checking for gccā¦ gcc
checking whether the C compiler worksā¦ no
configure: error: in /Users/Dalglish/Documents/Arduino/libraries/blynk-library-0.3.1/scripts/socat-2.0.0-b9': configure: error: C compiler cannot create executables See
config.logā for more details
Peters-Mac-mini-i7:socat-2.0.0-b9 Dalglish$ make
xcode-select: note: no developer tools were found at ā/Applications/Xcode.appā, requesting install. Choose an option in the dialog to download the command line developer tools.
Peters-Mac-mini-i7:socat-2.0.0-b9 Dalglish$ su
Password:
su: Sorry
it asks me to download developer tools! ā¦ I this would really slow down my macā¦ Xcode made it run really slow in the past.
Itās the only way to get it working, besides buying an ethernet shield or wifi shield for your Arduino, which is ultimately a better idea in any case
I bought the ethernet shield as described earlier in my thread but that failed to work on the mac. I was instructed to follow usb route.
