Hey! I’am working with my project so I need blynk server which is located in India if anyone can send the ip address it vill b very help full for me
You are in India.
Ask Google what ping does?
don’t provide it as this IP is based on the nearest server to your country , every body mileage will vary
This is for India. I use it from India. It took me a while to get this. I normally use Google DNS servers and so was hard pressed to find this. My IFTTT worked on a specific day from the browser and I trapped the IP. IFTTT works well since then when I use this IP.
Unless you want to use webhooks, the IP does not matter. Using hostname in the sketch will work well.
