IOT mentoring water quality in swimming pool
Hi
I need help with my project which is"The system should be able to check the quality (pH, chlorine, temperature) of the water in swimming pool and record all the data in the cloud"
I have bought all three sensors which are sen0165 sensor gravity series analog ORP (chlorine),
ds18b20(temperature), and Gravity Analog pH sensor/ meter kit for Arduino (PH)
I have to connect the Arduino and the nodemcu and sensors as will I used blynk platform for reading data I’m stuck on the coding to connect all of them while I need code for Arduino first then code for nodemcu as well pleas hellp me :sob: :pray: :pray: :pray:
Hi
Hi sir can help me with my project I will be highly appreciate it​:pray::pray::pray:
You haven’t even given any details of the project, so how can you expect anyone to commit time and energy to assisting you?
The members of this forum generally try to point fellow Blynk users in the right direction with their projects, but it’s not a code factory and there is an expectation that your C++ coding skills will be good for a project like this.
Is this a real-life project, or a school assignment?
It’s my first time using Blynk community I apologize for that it’s Arduino coding
And for the project is I’m going to put the three sensors inside the swimming pool to detect the value of the three parameters (PH,Temperature,chlorine) and show the data on the Blynk platform it’s assignment
For this project I need to use Arduino Uno with NodeMCU
I hope that’s clear and if there any missing information I will be pleasure to answer you
Thank you so much
Is this for a pool that is run as a business?
Yeah it’s normal swimming pool
Like this one in the photo
It’s my assignments in university
