I have a Photon connected to a 4-way relay operating a garage door opener, reed sensors, DS18B20 to monitor outside temperature. My code is essentially setup like this:
Blynk.begin(auth);
timer.setInterval(1000, sendStatus);
timer.setInterval(800, CheckDoorStatus);
timer.setInterval(60000, TempSensorReading);
timer.setInterval(15000, updateWifi);
timer.setInterval((24 * 60 * 60 * 1000), UpdateTime);
- WiFi signal strength is a solid -65dB
- OneWire (2.0.1) and blynk (0.5.1) Library’s are being used
- Connected to Apple HomeKit (via Homebridge) to provide Siri support
My Issue
On a regular basis (multiple times per day), the Blynk iOS app shows my Photon as offline, during this time the Photon is still breathing cyan, Siri/HomeKit still operate the garage door and Particle.io shows the device online (and I can flash it).
What’s the best way to diagnose the Blynk issue? Is there a way I can particle.publish instead of serial print debug code? (as access with a notebook to the Photon location is not easy)
sendStatus() sends four Blynk.virtualWrite’s every second, shouldn’t this keep it alive or could that be a cause?
