Invalid token Try 3 ip and it is don't work
Hello. I read topic, and all answer does not work.
i try 3 ip. And it is not work.
http://139.59.206.133/2-QfVjlabnyLxuRyoaEOjutv4N1wI9gv/project
http://188.166.206.43/2-QfVjlabnyLxuRyoaEOjutv4N1wI9gv/project
45.55.96.146/2-QfVjlabnyLxuRyoaEOjutv4N1wI9gv/project
Pleas help.
Are you using Blynk Legacy or Blynk IoT (Blynk 2.0)?
If you are using Blynk Legacy with the Blynk cloud servers then what do you get if you ping blynk-cloud.com From your PC and from your phone?
i try.
PING blynk-cloud.com (139.59.206.133): 56 data bytes
64 bytes from 139.59.206.133: icmp_seq=0 ttl=251 time=58.080 ms
64 bytes from 139.59.206.133: icmp_seq=1 ttl=251 time=46.028 ms
I don’t now. How i mat chack it?
try set setting here - Dashboard
You’re using Blynk IoT.
The HTTP(S) API syntax that you are using is the syntax for Blynk Legacy, and the cloud server url and IP addresses are those for Blynk Legacy, so the wont work with Blynk IoT.
The documentation for the Blynk IoT HTTP(s) API is here:
https://docs.blynk.io/en/blynk.cloud/https-api-overview
I’s suggest that you read it all, including the “Troubleshooting” section which contains information about the correct URL to use if you are using services like IFTTT.
Thank you very much.
