Hello everyone, I flashed the esp32 board using the template from the blink site, everything works, now I wanted to make a shortcut according to this instruction:
made a ping cloud.blynk.cc
And gave me ip 139.59.206.133
Later I copied my auth token, and tried the get request
This is a simple demo of sending and receiving some data.
Be sure to check out other examples!
#define BLYNK_TEMPLATE_ID "XXXXXXXXXXXXX"
#define BLYNK_DEVICE_NAME "Quickstart Device"
#define BLYNK_AUTH_TOKEN "XXXXXXXXXXXXX"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
const int relayPin = 19;
char ssid[] = "XXXXXXXXXXXXX";
char pass[] = "XXXXXXXXXXXXX";
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt();
digitalWrite(relayPin, param.asInt());
// Update state
Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
pinMode(relayPin, OUTPUT);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// to avoid delay() function!
Secondly, you shouldn’t be hard-coding the IP address of the Blynk cloud servers for Blynk IoT, there is a much better solution which is to use the regional subdomain to identify the server, such as lon1.blynk.cloud for tge London server.
Thirdly, the API syntax has changed for Blynk IoT. The new syntax is documented here:
