Hi All,
I have been using Blynk with WifiManager on my Wemos D1 Mini for about a year or two now, and it has worked like a charm!
Recently, I have updated my libraries to:
Arduino IDE to 1.8.10
Blynk to 0.6.1
WifiManager to 0.15.0 - beta
Since then, I am unable to communicate with Blynk, and on my Serial Monitor I see:
[46610] Connecting to blynk-cloud.com:80
[46821] Invalid auth token
Although when I connect to Blynk without WifiManager (Blynk.begin(auth, ssid, pass);), with the same token, it works fine.
Is this a WifiManager bug, or am I doing something extremely stupid?
Here is my code:
#include <WiFiManager.h>
char auth[] = "My_thirty_two_charac_autho_token";
// wifi
WiFi.disconnect();
WiFiManager wifiManager;
wifiManager.autoConnect("SMS Config WiFi");
Serial.println("Connected!");
WiFiManagerParameter custom_blynk_token("Blynk", "blynk token", auth, 34);
wifiManager.addParameter(&custom_blynk_token);
Serial.println(custom_blynk_token.getValue());
wifiManager.autoConnect("Blynk");
Blynk.config(custom_blynk_token.getValue());
//gets called when WiFiManager enters configuration mode
void configModeCallback (WiFiManager *myWiFiManager) {
Serial.println("Entered config mode");
Serial.println(WiFi.softAPIP());
//if you used auto generated SSID, print it
Serial.println(myWiFiManager->getConfigPortalSSID());
