Invalid auth token on Reconnection Wifi and Blynk
I’m trying to handle WiFi / Blynk reconnection when a disconnection happens.
My problem is that first connection to Blynk goes OK, if happens a disconnection I get following error (Invalid auth token) at reconnection.
Follows log retrieved in my attempts:
[2216] Connecting to xxxxxxxxxxxxxxxxxxxxx
[5250] AT version:0.22.0.0(Mar 20 2015 10:04:26)
SDK version:1.0.0
compile time:Mar 20 2015 11:00:32
[10313] +CIFSR:STAIP,“xxxxxxxxxxxxxxxxxxxxx”
+CIFSR:STAMAC,“xxxxxxxxxxxxxxxxxxxxx”
[10314] Connected to WiFi
[10809] Ready (ping: 12ms).
[20170331_213237][11555][4934]BLYNK - BLYNK_CONNECTED - Prima connessione
[20170331_213237][14373][5021]BLYNK - Arduino connesso
[14449] Time sync: OK
[20170331_221707][2639471][5021]BLYNK - Arduino disconnesso
[20170331_221853][2746112][5021]WIFI - Riavvio Esp8266
[2750141] Connecting to FASTWEB-1-5E6535
[2753176] AT version:0.22.0.0(Mar 20 2015 10:04:26)
SDK version:1.0.0
[2763214] Failed to connect WiFi
[20170331_221922][2774772][4989]TEMPERATURA - ARDUINO - T.: 21.00 U.: 42.00 %
[20170331_221922][2775317][4989]TEMPERATURA - ESTERNA - T.: 22.50 U.: 45.70 %
[20170331_221922][2775321][5021]WIFI - Riavvio Esp8266
[2779350] Connecting to xxxxxxxxxxxxxxxxxxxxx
[2782385] AT version:0.22.0.0(Mar 20 2015 10:04:26)
SDK version:1.0.0
[2787447] +CIFSR:STAIP,“xxxxxxxxxxxxxxxxxxxxx”
[2787448] Connected to WiFi
[2787628] Invalid auth token
[2788275] Invalid auth token
[2788919] Invalid auth token
[2789880] Invalid auth token
[2790218] Invalid auth token
[2790866] Invalid auth token
[2791511] Invalid auth token
[2792440] Invalid auth token
[2792889] Invalid auth token
In this case connection fails for a router restart (as you can see from “Failed to connect WiFi”), but happens also without a router restart (for example a simple connection fall)
Code that handle the first connection (in setup) and reconnection (in loop) is:
	previousConnected = false;
	delay(100);
	Blynk.config(wifi, BLYNK_AUTH);
	Blynk.connectWiFi(BLYNK_SSID, BLYNK_PWD);
	Blynk.connect();
	timer.setInterval(1000, primaSincronizzazione);
	timer.setInterval(2000, primaSincronizzazioneLow);
	if (Blynk.connected()) {
		timeToRetry = T_RETRY;
		nRetry = 0;
		if (!previousConnected) {
			previousConnected = true;
			disconnectionTime = 0;
			Log::stampa(F("BLYNK - Arduino connesso"));
			rtc.begin();
			setSyncInterval(900);
	else {
		if (nRetry >= MAX_RETRY)
			timeToRetry = EXTENDED_T_RETRY;
		if (disconnectionTime != 0 &&  millis() - disconnectionTime > timeToRetry) {
			Log::stampa(F("WIFI - Riavvio Esp8266"));
			disableWDT();
			wifi.restart();
			Blynk.connect();
			nRetry++;
			enableWDT();
		if (previousConnected) {
			disconnectionTime = millis();
			Log::stampa(F("BLYNK - Arduino disconnesso"));
I’m on Library v0.4.4 and Server Blynk Cloud.
Hardware: Arduino Mega + ESP8266.
Where I’m wrong in reconnection handling?
Thanks.
Regards
I’m sorry for unnecessary post.
I solved my problem adding:
after Wifi restart, as follow:
			wifi.restart();
			Blynk.connect();
