hills8
April 9, 2018, 7:33am
1
• Hardware model + communication type.
NodeMCU with Wifi
• Smartphone OS
Android OS
Local Server
• Blynk Library version
0.5.0
• sketch code.
This Project include 3 Devices, 2 of them connecting succesful, The new device doesn’t
same (working code) with auth token:
char auth[] = “5fbc5f8ca25746958eb8da76eb8960f8”;
here the token from local Admin Page: (http://192.168.0.59:8080/admin#/users/edit/
BoardType: ESP8266 (also tried with NodeMCU)
Token: 5fbc5f8ca25746958eb8da76eb8960f8
LastLoggedIP
ConnectionType: WI_FI
I tried to change the token round about 10 times, no success.
Device in Admin page and also Android application deleted and new added after log off and log on, no success.
still:
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.5.0 on NodeMCU
[21746] Connecting to 192.168.0.59
[21763] Invalid auth token
[26758] Connecting to 192.168.0.59
[26769] Invalid auth token
[31764] Connecting to 192.168.0.59
[31772] Invalid auth token
any ideas?
regards hills8
*Edit: also tried to reboot Blynk Server and Raspberry.
*Edit2: serial print with active debugging:
[42321] Connecting to 192.168.0.59
[42324] <[02|00|01|00]#[E2|80|8B]5fbc5f8ca25746958eb8da76eb8960f8
[42331] >[00|00|01|00|09]
[42331] Invalid auth token
Gunner
April 9, 2018, 8:01am
2
Can you show screenshots of your My Devices page and of the Device in question?
For example…
Gunner
April 9, 2018, 8:43am
4
OK, please show FULL sketch, with same AUTH token, of the affected device.
Format it after pasting here like this…
hills8
April 9, 2018, 8:48am
5
#define BLYNK_DEBUG
#include <ESP8266HTTPClient.h>
#include <ArduinoJson.h>
#include <WiFiClient.h>
#include <WiFiUdp.h>
#include <TimeLib.h> //download at https://github.com/PaulStoffregen/Time
#include <ArduinoOTA.h>
// your settings -------
char ssid[] = "(.)(.)";
char pass[] = "Welcome2(.)(.)";
char auth[] = "5fbc5f8ca25746958eb8da76eb8960f8";
//Blynk.config(auth);
//Blynk.connectWiFi(ssid, pass);
//Blynk.disconnect();
Serial.println("connecting to Blynk Server");
Blynk.begin(auth, ssid, pass, IPAddress(192,168,0,59));
Serial.println("Connection etablished!");
ArduinoOTA.handle();
Gunner
April 9, 2018, 8:58am
6
Try this simpler sketch…
char server[] = "192.168.0.59";
int port = 8080;
Serial.println("Connecting to Blynk Server");
WiFi.begin(ssid, pass);
Blynk.config(auth, server, port);
Blynk.connect();
BLYNK_CONNECTED() { // Run this function when connected to server
Serial.println("Connection established!");
hills8
April 9, 2018, 9:18am
7
Login timeout.
I changed the Port to 8442 and get “Invalid token” again.
Here the device in my blynk admin:
Gunner
April 9, 2018, 9:27am
8
Why?.. the proper port in the script to use is 8080.
What is your Local Server version?
hills8
April 9, 2018, 9:34am
9
my server version is still 0.33.1
regards hills8
Gunner
April 9, 2018, 9:37am
10
You need to keep current with all updates on App, Server and Libraries… they are all intertwined and leaving one or more behind will cause these types of issues.
NOTE: you will need to make port changes to App (9443) and sketches (8080)… possibly even to any port forwarding you may have.
It is important to keep checking any new Announcements topics… saves us time troubleshooting something due to old components.
In this release
New hardware support:
TI CC3220 (Energia IDE)
General improvements
Blynk switched to using port 80 by default.
Certificates added for easier switching from Blynk Cloud to Let’s Encrypt
Add setMin & setMax to widgets
Bugfixes:
Fix pinMode command
Fix ESP32 WiFi credentials provisioning
PlatformIO , Particle , ARM mbed and OpenWRT packages have been updated accordingly.
Full list of supported hardware is available here
NOTE: if you have local server and uploa…
hills8
April 9, 2018, 9:40am
11
Okay, will Update all. Thank you
hills8
April 9, 2018, 10:11am
12
Okay, Library updated to v 0.5.2
server updated to 0.34.1
port changed back to 8080
[242847] Connecting to 192.168.0.59:8080
[242850] <[02|00|01|00]#[E2|80|8B]5fbc5f8ca25746958eb8da76eb8960f8
[242857] >[00|00|01|00|09]
[242857] Invalid auth token
AND i am not able to open the admin page anymore. I tired:
```cpp sudo iptables -t nat -A PREROUTING -p tcp --dport 80 -j REDIRECT --to-port 8080 ````
and open following pages
(http://192.168.0.59:7443/admin )
(http://192.168.0.59:8080/admin )
(http://192.168.0.59:80/admin )
hills8
https:// i missed that one…
hills8
April 9, 2018, 10:30am
16
hills8
April 9, 2018, 10:36am
18
but the server seems to listen to that port:
sudo netstat -tlpn Aktive Internetverbindungen (Nur Server)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 462/sshd
tcp 0 0 0.0.0.0:3306 0.0.0.0:* LISTEN 585/mysqld
tcp6 0 0 :::22 :::* LISTEN 462/sshd
tcp6 0 0 :::8440 :::* LISTEN 405/java
tcp6 0 0 :::8441 :::* LISTEN 405/java
tcp6 0 0 :::9443 :::* LISTEN 405/java
tcp6 0 0 :::8080 :::* LISTEN 405/java
hills8
Dmytro
April 9, 2018, 10:39am
19
80|8B this seems to be some invisible chars before your auth token. Try to remove your token and copy again without “hidden” chars.
Unicode copy/paste error?
U+200B 0xe2 0x80 0x8b <-- matches the pattern
EDIT: U+200B = Zero width space…
