Hello, Very Important request , I have read all the solutions to this problem here and have applied the necessary changes like #define BLYNK_TEMPLATE_ID position , Blynk latest version 1.3.2 , but I still am having this issue. Here , I have provided the code please forgive my formatting if wrong. I have also put Serial Monitor Output. Please Pete or John reply to me as soon as you can.
#define BLYNK_TEMPLATE_ID "XXXXXXXXX"
#define BLYNK_TEMPLATE_NAME "XXXXXXX"
#define BLYNK_AUTH_TOKEN "XXXXXXXXXXXX"
#include <Wire.h>
#include <OneWire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <DHT.h> // Including library for dht
char auth[] = "XXXXXXXXXXX"; //Authentication code sent by Blynk
char ssid[] = "XXXXXXXXXXX"; //WiFi SSID
char pass[] = "XXXXX"; //WiFi Password
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define DHTPIN D4 //pin where the dht11 is connected
DHT dht(DHTPIN, DHT22);
#define ONE_WIRE_BUS D6
#define buzzer D5 //Buzzer Pin D5
#define rainPin D7
int rainState = 0;
int lastRainState = 0;
const int AirValue = 590; //you need to replace this value with Value_1
const int WaterValue = 300; //you need to replace this value with Value_2
const int SensorPin = A0;
int soilMoistureValue = 0;
int soilmoisturepercent = 0;
int relay = D0;
#define pirPin D3
int pirValue;
int pinValue;
//Read value from blynk
BLYNK_WRITE(V0)
pinValue = param.asInt();
delay(100);
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); //initialize with the I2C addr 0x3C (128x64)
display.clearDisplay();
pinMode(relay, OUTPUT);
pinMode(buzzer, OUTPUT);
sensors.begin(); // Dallas temperature
dht.begin();
void getPirValue(void) //Get PIR Data
pirValue = digitalRead(pirPin);
if (pirValue)
Serial.println("Motion detected");
Blynk.logEvent("Motion detected in your farm") ;
float h = dht.readHumidity();
float temp = sensors.getTempCByIndex(0);
Serial.print("Soil Temperature: ");
Serial.println(temp);
Serial.println(t);
Serial.print("Humidity: ");
Serial.println(h);
Blynk.virtualWrite(V3, t); //V3 is for Temperature
Blynk.virtualWrite(V4, h); //V4 is for Humidity
Blynk.virtualWrite(V2, temp); //Dallas Temperature
soilMoistureValue = analogRead(SensorPin); //put Sensor insert into soil
Serial.println(soilMoistureValue);
soilmoisturepercent = map(soilMoistureValue, AirValue, WaterValue, 0, 100);
Blynk.virtualWrite(V1, soilmoisturepercent); //Soil Moisture sensor
if (soilmoisturepercent > 100)
Serial.println("100 %");
delay(1500);
// display Soil temperature
display.setTextColor(WHITE);
display.setTextSize(1);
display.setCursor(0, 5);
display.print("RH of Soil: ");
display.print("100");
display.print(" %");
// display Air temperature
display.setCursor(0, 20);
display.print("Soil Temp: ");
display.print(temp);
display.print(" ");
display.cp437(true);
display.write(167);
display.print("C");
// display relative humidity of Soil
display.setCursor(0, 35);
display.print("Air Temp: ");
display.print(t);
display.print(" ");
display.write(167);
display.print("C");
// display relative humidity of Air
display.setCursor(0, 50);
display.print("RH of Air: ");
display.print(h);
display.display();
delay(1500);
else if (soilmoisturepercent < 0)
Serial.println("0 %");
delay(1500);
display.print("0");
display.print(" ");
display.write(167);
display.print("C");
display.print(t);
display.print(" ");
display.write(167);
display.print("C");
display.print(h);
display.display();
delay(1500);
else if (soilmoisturepercent >= 0 && soilmoisturepercent <= 100)
Serial.print(soilmoisturepercent);
Serial.println("%");
delay(1500);
display.print(soilmoisturepercent);
display.print(" ");
display.write(167);
display.print("C");
display.print(t);
display.print(" ");
display.write(167);
display.print("C");
display.print(h);
display.display();
delay(1500);
if (soilmoisturepercent >= 0 && soilmoisturepercent <= 30)
Serial.println("needs water, send notification");
//send notification
Blynk.logEvent("Plants need water... Pump is activated") ;
digitalWrite(relay, LOW);
digitalWrite(buzzer, HIGH);
Serial.println("Motor is ON");
WidgetLED PumpLed(V5);
PumpLed.on();
else if (soilmoisturepercent > 30 && soilmoisturepercent <= 100)
Serial.println("Soil Moisture level looks good...");
digitalWrite(relay, HIGH);
digitalWrite(buzzer, LOW);
Serial.println("Motor is OFF");
PumpLed.off();
rainState = digitalRead(rainPin);
Serial.println(rainState);
if (rainState == 0 && lastRainState == 0) {
Serial.println("It's Raining outside!");
Blynk.logEvent("It's Raining outside!") ;
lastRainState = 1;
//send notification
else if (rainState == 0 && lastRainState == 1) {
else {
Serial.println("No Rains...");
lastRainState = 0;
if (pinValue == HIGH)
getPirValue();
delay(100);
