Hi.
I’m having a problem with the auth token, i was trying to control my Arduino Uno board through Blynk with the Nodemcu ESP8266. I was following a guide on arduino project hub and the auth token i have was invalid. It’s my fist time using Blynk and Nodemcu so if anyone could help me i’ll be very grateful.
http://twitter.com/blynk_app
This example shows how to use ESP8266 Shield (with AT commands)
to connect your project to Blynk.
WARNING!
It's very tricky to get it working. Please read this article:
http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
#include <ESP8266_Lib.h>
char auth[] = "Fl3EEUo_K2Y2NYfRcff8jRMaGmTzgVql";
char ssid[] = "xxxxxxxx";
char pass[] = "xxxxxxxx";
#define ESP8266_BAUD 115200
ESP8266 wifi(&Serial);
// Set ESP8266 baud rate
Serial.begin(ESP8266_BAUD);
Here the terminal:
