I am getting this error when i tried to intergate ESP32 with sim800c
i tried the hardware connecton according TTGO T CALL but cant connect to the blynk server
This is the code i am using
- For this example, you need to install Blynk library:
- https://github.com/blynkkk/blynk-library/releases/latest
- TinyGSM Getting Started guide:
- https://tiny.cc/tinygsm-readme
- Blynk is a platform with iOS and Android apps to control
- Arduino, Raspberry Pi and the likes over the Internet.
- You can easily build graphic interfaces for all your
- projects by simply dragging and dropping widgets.
- Blynk supports many development boards with WiFi, Ethernet,
- GSM, Bluetooth, BLE, USB/Serial connection methods.
- See more in Blynk library examples and community forum.
http://www.blynk.io/
- Change GPRS apm, user, pass, and Blynk auth token to run
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
// #define BLYNK_HEARTBEAT 30
// Please select the corresponding model
// #define SIM800L_IP5306_VERSION_20190610
// #define SIM800L_AXP192_VERSION_20200327
//#define SIM800C_AXP192_VERSION_20200609
// #define SIM800L_IP5306_VERSION_20200811
//#include “utilities.h”
#define MODEM_TX 16
#define MODEM_RX 17
// Select your modem:
#define TINY_GSM_MODEM_SIM800
// Set serial for debug console (to the Serial Monitor, default speed 115200)
#define SerialMon Serial
// Set serial for AT commands (to the module)
// Use Hardware Serial on Mega, Leonardo, Micro
#define SerialAT Serial2
// See all AT commands, if wanted
//#define DUMP_AT_COMMANDS
// Define the serial console for debug prints, if needed
#define TINY_GSM_DEBUG SerialMon
// set GSM PIN, if any
#define GSM_PIN “”
// Your GPRS credentials, if any
const char apn[] = “dialogbb”;
const char gprsUser[] = “”;
const char gprsPass[] = “”;
#include <TinyGsmClient.h>
#ifdef DUMP_AT_COMMANDS
#include <StreamDebugger.h>
StreamDebugger debugger(SerialAT, SerialMon);
TinyGsm modem(debugger);
#else
TinyGsm modem(SerialAT);
TinyGsmClient client(modem);
const char auth[] = “”;
// Set console baud rate
SerialMon.begin(115200);
//setupModem();
SerialMon.println("Wait...");
// Set GSM module baud rate and UART pins
SerialAT.begin(115200, SERIAL_8N1, MODEM_RX, MODEM_TX);
delay(6000);
SerialMon.println("Initializing modem...");
modem.restart();
// modem.init();
//String modemInfo = modem.getModemInfo();
//SerialMon.print("Modem Info: ");
//SerialMon.println(modemInfo);
// Unlock your SIM card with a PIN
//modem.simUnlock("1234");
Blynk.begin(auth, modem, apn, gprsUser, gprsPass);
Please don’t post screenshots of your serial output, it’s almost impossible to read.
Instead, you should copy the data from your serial monitor and paste it into your post, with triple backticks at the beginning and end so that it displays correctly.
It’s not clear from your post if you are actually using a TTGO T-Call or and ESP32 and a SIM800C module.
If it’s a separate module then you need to explain how that is wired and post your code, including the code from any additional tabs.
Your code also needs to be posted between triple backticks. Unformatted code will be deleted.
Also, you should upgrade your Blynk library to 0.6.1
