I trying to write the coding for DHT11, rain sensor, and water flow sensor. Before I combine water flow sensor coding with DHT11 and rain sensor coding, the serial monitor prints the corrects output. After I combine the coding all together then the serial monitor prints the wrong output which is the water flow sensor not working (no water flow through) but there will have value run on the serial monitor.
Anyone can help me to figure out the issue and help me troubleshoot the coding?
//**coding before add in water flow sensor**
#include <ESP8266_Lib.h>
#include <DHT.h>
char auth[] = "xxx";
char ssid[] = "xxx";
char pass[] = "xxx";
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
const int sensorMin = 0; // sensor minimum
const int sensorMax = 1024; // sensor maximum
#define DHTPIN 4 // What digital pin we're connected to
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
// Set ESP8266 baud rate
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
Serial.print("\n");
//Blynk.begin(auth, wifi, ssid, pass, "blynk.cloud", 80);
dht.begin();
// read the sensor on analog A0:
int sensorReading = analogRead(A0);
// map the sensor range (four options):
// ex: 'long int map(long int, long int, long int, long int, long int)'
int range = map(sensorReading, sensorMin, sensorMax, 0, 3);
// range value:
switch (range) {
case 0: // Sensor getting more wet
Serial.println("Flood");
break;
case 1: // Sensor getting wet
Serial.println("Rain Warning");
break;
case 2: // Sensor dry - To shut this up delete the " Serial.println("Not Raining"); " below.
break;
delay(1000); // delay between reads
//**this is water flow sensor coding**
int statusLed = 13; // byte stores an 8-bit unsigned number, from 0 to 255.
int sensorInterrupt = 0; // 0 = digital pin 2
int sensorPin = 2;
// The hall-effect flow sensor outputs approximately 4.5 pulses per second per
// litre/minute of flow.
float calibrationFactor = 4.5;
volatile byte pulseCount;
float flowRate;
unsigned int flowMilliLitres;
unsigned long totalMilliLitres;
unsigned long oldTime;
// Initialize a serial connection for reporting values to the host
// Set up the status LED line as an output
pinMode(statusLed, OUTPUT);
digitalWrite(statusLed, HIGH); // We have an active-low LED attached
pinMode(sensorPin, INPUT);
digitalWrite(sensorPin, HIGH);
pulseCount = 0;
flowRate = 0.0;
flowMilliLitres = 0;
totalMilliLitres = 0;
oldTime = 0;
// The Hall-effect sensor is connected to pin 2 which uses interrupt 0.
// Configured to trigger on a FALLING state change (transition from HIGH
// state to LOW state)
attachInterrupt(sensorInterrupt, pulseCounter, FALLING);
* Main program loop
if((millis() - oldTime) > 1000) // Only process counters once per second
// Disable the interrupt while calculating flow rate and sending the value to
// the host
detachInterrupt(sensorInterrupt);
// Because this loop may not complete in exactly 1 second intervals we calculate
// the number of milliseconds that have passed since the last execution and use
// that to scale the output. We also apply the calibrationFactor to scale the output
// based on the number of pulses per second per units of measure (litres/minute in
// this case) coming from the sensor.
flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
// Note the time this processing pass was executed. Note that because we've
// disabled interrupts the millis() function won't actually be incrementing right
// at this point, but it will still return the value it was set to just before
// interrupts went away.
oldTime = millis();
// Divide the flow rate in litres/minute by 60 to determine how many litres have
// passed through the sensor in this 1 second interval, then multiply by 1000 to
// convert to millilitres.
flowMilliLitres = (flowRate / 60) * 1000;
// Add the millilitres passed in this second to the cumulative total
totalMilliLitres += flowMilliLitres;
unsigned int frac;
// Print the flow rate for this second in litres / minute
Serial.print("Flow rate: ");
Serial.print(int(flowRate)); // Print the integer part of the variable
Serial.print("L/min");
Serial.print("\t"); // Print tab space
// Print the cumulative total of litres flowed since starting
Serial.print("Output Liquid Quantity: ");
Serial.print(totalMilliLitres);
Serial.println("mL");
// Reset the pulse counter so we can start incrementing again
pulseCount = 0;
// Enable the interrupt again now that we've finished sending output
Insterrupt Service Routine
void pulseCounter()
// Increment the pulse counter
pulseCount++;
