Good afternoon.
Looking for a solution to the problem in the topics, but never got to the point.
I use Arduino Nano in conjunction with A7 GPRS/GSM/GPS module.
For communication, I use Software Serial on 4 and 5 pin. BaudRate = 9600/
Library: TinyGsmClient, NMEAGPS, BlynkSimpleTinyGSM, SoftwareSerial.
If you run a sketch that does not use Blynk, but simply connects to the A7 module and outputs data to the port monitor with GPS, then everything is beautiful. The data is there, they can be disassembled.
But, wanted to use Blynk for the shell to conveniently transmit GPS coordinates from the A7 module to the Blynk application, such as the Map widget, or just latitude and longitude to virtual variables.
And here there was a problem if in a loop loop blynk,run () works, as I understand, it processes all data from Software Serial itself.
Therefore, I sketch, I do not have to catch separately, which entered the data and checked for NMEA, and then disassemble them.
If you run Blynk.run() on a timer (which of course contradicts the documentation), then the first time the sketch works, I get the data, and they are sent to the widget.
But, after a while, I lose my connection to Blynk.
Tell me, what can be the solution to this issue? You may need some way to track the flow of exchange Blynk in arduino? and from it already take the necessary data, if they are in NMEA format?
The code of the sketch
#include <NMEAGPS.h>
#define TINY_GSM_MODEM_A7
#include <TinyGsmClient.h>
int j = 0;
#define BLYNK_DEBUG
#define BLYNK_TIMEOUT_MS 6000UL
#define BLYNK_HEARTBEAT 60
//#define BLYNK_DEBUG_ALL Serial
// Your GPRS credentials
// Leave empty, if missing user or pass
const char apn[] = "";
const char user[] = "";
const char pass[] = "";
const char auth[] = "Здесь код устройства Blynk";
//#include <SoftwareSerial.h>
//SoftwareSerial GSM_m(4, 5); // RX, TX
WidgetTerminal terminal(V1);
// Program: NMEA.ino
// Description: This program uses the fix-oriented methods available() and
// read() to handle complete fix structures.
// When the last character of the LAST_SENTENCE_IN_INTERVAL (see NMEAGPS_cfg.h)
// is decoded, a completed fix structure becomes available and is returned
// from read(). The new fix is saved the 'fix' structure, and can be used
// anywhere, at any time.
// If no messages are enabled in NMEAGPS_cfg.h, or
// no 'gps_fix' members are enabled in GPSfix_cfg.h, no information will be
// parsed, copied or printed.
// Prerequisites:
// 1) Your GPS device has been correctly powered.
// Be careful when connecting 3.3V devices.
// 2) Your GPS device is correctly connected to an Arduino serial port.
// See GPSport.h for the default connections.
// 3) You know the default baud rate of your GPS device.
// If 9600 does not work, use NMEAdiagnostic.ino to
// scan for the correct baud rate.
// 4) LAST_SENTENCE_IN_INTERVAL is defined to be the sentence that is
// sent *last* in each update interval (usually once per second).
// The default is NMEAGPS::NMEA_RMC (see NMEAGPS_cfg.h). Other
// programs may need to use the sentence identified by NMEAorder.ino.
// 5) NMEAGPS_RECOGNIZE_ALL is defined in NMEAGPS_cfg.h
// 'Serial' is for debug output to the Serial Monitor window.
// License:
// Copyright (C) 2014-2017, SlashDevin
// This file is part of NeoGPS
// NeoGPS is free software: you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation, either version 3 of the License, or
// (at your option) any later version.
// NeoGPS is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with NeoGPS. If not, see <http://www.gnu.org/licenses/>.
// The GPSport.h include file tries to choose a default serial port
// for the GPS device. If you know which serial port you want to use,
// edit the GPSport.h file.
#include <GPSport.h>
// For the NeoGPS example programs, "Streamers" is common set
// of printing and formatting routines for GPS data, in a
// Comma-Separated Values text format (aka CSV). The CSV
// data will be printed to the "debug output device".
// If you don't need these formatters, simply delete this section.
#include <Streamers.h>
// This object parses received characters
// into the gps.fix() data structure
static NMEAGPS gps;
// Define a set of GPS fix information. It will
// hold on to the various pieces as they are received from
// an RMC sentence. It can be used anywhere in your sketch.
static gps_fix fix;
// This function gets called about once per second, during the GPS
// quiet time. It's the best place to do anything that might take
// a while: print a bunch of things, write to SD, send an SMS, etc.
// By doing the "hard" work during the quiet time, the CPU can get back to
// reading the GPS chars as they come in, so that no chars are lost.
static void doSomeWork()
// Print all the things!
trace_all( DEBUG_PORT, gps, fix );
trace_all( terminal, gps, fix );
} // doSomeWork
//#define DUMP_AT_COMMANDS
#define TINY_GSM_DEBUG DEBUG_PORT
#ifdef DUMP_AT_COMMANDS
#include <StreamDebugger.h>
StreamDebugger debugger(gpsPort, DEBUG_PORT);
TinyGsm modem(debugger);
#else
TinyGsm modem(gpsPort);
#endif
void RepeatTask() {
DEBUG_PORT.println("1 second timer for run");
// This is the main GPS parsing loop.
static void GPSloop()
while (gps.available( gpsPort )) {
DEBUG_PORT.println("GPS Availible!");
fix = gps.read();
doSomeWork();
} // GPSloop
DEBUG_PORT.begin(9600);
while (!DEBUG_PORT)
DEBUG_PORT.print( F("NMEA.INO: started\n") );
DEBUG_PORT.print( F(" fix object size = ") );
DEBUG_PORT.println( sizeof(gps.fix()) );
DEBUG_PORT.print( F(" gps object size = ") );
DEBUG_PORT.println( sizeof(gps) );
DEBUG_PORT.println( F("Looking for GPS device on " GPS_PORT_NAME) );
#ifndef NMEAGPS_RECOGNIZE_ALL
#error You must define NMEAGPS_RECOGNIZE_ALL in NMEAGPS_cfg.h!
#endif
#ifdef NMEAGPS_INTERRUPT_PROCESSING
#error You must *NOT* define NMEAGPS_INTERRUPT_PROCESSING in NMEAGPS_cfg.h!
#endif
#if !defined( NMEAGPS_PARSE_GGA ) & !defined( NMEAGPS_PARSE_GLL ) & \
!defined( NMEAGPS_PARSE_GSA ) & !defined( NMEAGPS_PARSE_GSV ) & \
!defined( NMEAGPS_PARSE_RMC ) & !defined( NMEAGPS_PARSE_VTG ) & \
!defined( NMEAGPS_PARSE_ZDA ) & !defined( NMEAGPS_PARSE_GST )
DEBUG_PORT.println( F("\nWARNING: No NMEA sentences are enabled: no fix data will be displayed.") );
#else
if (gps.merging == NMEAGPS::NO_MERGING) {
DEBUG_PORT.print ( F("\nWARNING: displaying data from ") );
DEBUG_PORT.print ( gps.string_for( LAST_SENTENCE_IN_INTERVAL ) );
DEBUG_PORT.print ( F(" sentences ONLY, and only if ") );
DEBUG_PORT.println( F(" is enabled.\n"
" Other sentences may be parsed, but their data will not be displayed.") );
#endif
DEBUG_PORT.print ( F("\nGPS quiet time is assumed to begin after a ") );
DEBUG_PORT.println( F(" sentence is received.\n"
" You should confirm this with NMEAorder.ino\n") );
trace_header( DEBUG_PORT );
DEBUG_PORT.flush();
gpsPort.begin( 9600 );
DEBUG_PORT.println("Activation GPS ...");
gpsPort.println("AT+GPS=1"); // Включаем GPS
delay(3000);
gpsPort.println("AT+GPSRD=1"); // Включаем GPS данные
timer.setInterval(1000, RepeatTask);
//terminal.clear();
DEBUG_PORT.println("Started!");
if (j==0) {
DEBUG_PORT.println("Run!");
j=1;}
GPSloop();
//Blynk.run();
Here’s what I get in the serial port monitor:
18:19:52.806 -> NMEA.INO: started
18:19:52.806 -> fix object size = 31
18:19:52.840 -> gps object size = 84
18:19:52.873 -> Looking for GPS device on SoftwareSerial( RX pin 4, TX pin 5 )
18:19:52.942 ->
18:19:52.942 -> GPS quiet time is assumed to begin after a RMC sentence is received.
18:19:53.010 -> You should confirm this with NMEAorder.ino
18:19:53.043 ->
18:19:53.043 -> Status,UTC Date/Time,Lat,Lon,Hdg,Spd,Alt,Sats,Rx ok,Rx err,Rx chars,
18:19:53.111 -> [328]
18:19:53.146 -> ___ __ __
18:19:53.146 -> / _ )/ /_ _____ / /__
18:19:53.180 -> / _ / / // / _ \/ '_/
18:19:53.213 -> /____/_/\_, /_//_/_/\_\
18:19:53.247 -> /___/ v0.6.1 on Arduino Nano
18:19:53.281 ->
18:19:53.281 -> [420] Modem init...
18:19:57.727 -> [4907] Connecting to network...
18:19:59.286 -> [6463] Network: MegaFon
18:19:59.286 -> [6463] Connecting to ...
18:20:05.049 -> [12239] Connected to GPRS
18:20:05.252 -> [12419] Connecting to blynk-cloud.com:80
18:20:08.816 -> [15976] <[1D|00|01|00] "Here is the Blynk device code"
18:20:09.937 -> [17101] >[00|00|01|00|C8]
18:20:09.937 -> [17102] Ready (ping: 108ms).
18:20:09.971 -> [17103] Free RAM: 552
18:20:10.006 -> [17187] <[11|00|02|00]bver[00]0.6.1[00]h-beat[00]60[00]buff-in[00]256[00]dev[00]Arduino Nano[00]cpu[00]ATmega328P[00]con[00]A7[00]build[00]Aug 16 2019 18:16:14[00]
18:20:10.923 -> Activation GPS ...
18:20:14.931 -> Started!
18:20:14.931 -> Run!
18:20:15.201 -> GPS Availible!
18:20:15.201 -> 0,,,,,,,0,2,0,129,
18:20:15.957 -> 1 second timer for run
18:20:16.161 -> GPS Availible!
18:20:16.161 -> 0,,,,,,,0,5,0,223,
18:20:16.941 -> 1 second timer for run
18:20:17.179 -> GPS Availible!
18:20:17.179 -> 0,,,,,,,0,8,0,316,
18:20:17.962 -> 1 second timer for run
18:20:18.266 -> GPS Availible!
18:20:18.266 -> 0,,,,,,,0,13,0,458,
18:20:18.334 -> [25508] <[14|00|03|00]Evw[00]1[00]0,,,,,,,0,2,0,129,[0A]0,,,,,,,0,5,0,223,[0A]0,,,,,,,0,8,0,316,[0A]0,,,,,,
18:20:20.233 -> 1 second timer for run
18:20:20.946 -> 1 second timer for run
18:20:21.184 -> GPS Availible!
18:20:21.184 -> 0,,,,,,,0,15,0,525,
18:20:21.968 -> 1 second timer for run
18:20:22.172 -> GPS Availible!
18:20:22.172 -> 0,,,,,,,0,18,0,617,
18:20:22.952 -> 1 second timer for run
18:20:23.289 -> GPS Availible!
18:20:23.289 -> 0,,,,,,,0,23,0,760,
18:20:23.323 -> [30504] <[14|00|04|00]Evw[00]1[00],0,13,0,458,[0A]0,,,,,,,0,15,0,525,[0A]0,,,,,,,0,18,0,617,[0A]0,,,,,,,0,2
18:20:24.990 -> 1 second timer for run
18:20:25.193 -> GPS Availible!
18:20:25.193 -> 0,,,,,,,0,25,0,826,
18:20:25.971 -> 1 second timer for run
18:20:26.175 -> GPS Availible!
18:20:26.175 -> 0,,,,,,,0,28,0,920,
18:20:26.962 -> 1 second timer for run
18:20:27.163 -> GPS Availible!
18:20:27.163 -> 0,,,,,,,0,31,0,1013,
18:20:27.230 -> [34400] <[14|00|05|00]Evw[00]1[00]3,0,760,[0A]0,,,,,,,0,25,0,826,[0A]0,,,,,,,0,28,0,920,[0A]0,,,,,,,0,31,0,
18:20:28.859 -> 1 second timer for run
18:20:28.961 -> 1 second timer for run
18:20:29.166 -> GPS Availible!
18:20:29.166 -> 0,,,,,,,0,33,0,1079,
18:20:29.995 -> 1 second timer for run
18:20:30.181 -> GPS Availible!
18:20:30.181 -> 0,,,,,,,0,36,0,1173,
18:20:30.960 -> 1 second timer for run
18:20:31.164 -> GPS Availible!
18:20:31.164 -> 0,,,,,,,0,39,0,1266,
18:20:31.231 -> [38398] <[14|00|06|00]Evw[00]1[00]1013,[0A]0,,,,,,,0,33,0,1079,[0A]0,,,,,,,0,36,0,1173,[0A]0,,,,,,,0,39,0,1
18:20:32.965 -> 1 second timer for run
18:20:33.270 -> GPS Availible!
18:20:33.270 -> 0,,,,,,,0,43,0,1381,
18:20:33.980 -> 1 second timer for run
18:20:34.184 -> GPS Availible!
18:20:34.184 -> 0,,,,,,,0,46,0,1475,
18:20:34.963 -> 1 second timer for run
18:20:35.167 -> GPS Availible!
18:20:35.167 -> 0,,,,,,,0,49,0,1567,
18:20:35.235 -> [42393] <[14|00|07|00]Evw[00]1[00]266,[0A]0,,,,,,,0,43,0,1381,[0A]0,,,,,,,0,46,0,1475,[0A]0,,,,,,,0,49,0,15
18:20:36.862 -> 1 second timer for run
18:20:36.965 -> 1 second timer for run
18:20:37.168 -> GPS Availible!
18:20:37.168 -> 0,,,,,,,0,51,0,1633,
18:20:37.981 -> 1 second timer for run
18:20:38.287 -> GPS Availible!
18:20:38.287 -> 0,,,,,,,0,56,0,1775,
18:20:38.965 -> 1 second timer for run
18:20:39.169 -> GPS Availible!
18:20:39.169 -> 0,,,,,,,0,59,0,1869,
18:20:39.238 -> [46392] <[14|00|08|00]Evw[00]1[00]67,[0A]0,,,,,,,0,51,0,1633,[0A]0,,,,,,,0,56,0,1775,[0A]0,,,,,,,0,59,0,186
18:20:40.898 -> 1 second timer for run
18:20:40.966 -> 1 second timer for run
18:20:41.169 -> GPS Availible!
18:20:41.169 -> 0,,,,,,,0,61,0,1935,
18:20:41.984 -> 1 second timer for run
18:20:42.187 -> GPS Availible!
18:20:42.187 -> 0,,,,,,,0,64,0,2028,
18:20:42.972 -> 1 second timer for run
18:20:43.276 -> GPS Availible!
18:20:43.276 -> 0,,,,,,,0,69,0,2170,
18:20:43.345 -> [50491] <[14|00|09|00]Evw[00]1[00]9,[0A]0,,,,,,,0,61,0,1935,[0A]0,,,,,,,0,64,0,2028,[0A]0,,,,,,,0,69,0,2170
18:20:45.007 -> 1 second timer for run
18:20:45.176 -> GPS Availible!
18:20:45.176 -> 0,,,,,,,0,71,0,2237,
18:20:45.990 -> 1 second timer for run
18:20:46.193 -> GPS Availible!
18:20:46.193 -> 0,,,,,,,0,74,0,2329,
18:20:46.973 -> 1 second timer for run
18:20:47.177 -> GPS Availible!
18:20:47.177 -> 0,,,,,,,0,77,0,2423,
18:20:47.244 -> [54385] <[14|00|0A|00]Evw[00]1[00],[0A]0,,,,,,,0,71,0,2237,[0A]0,,,,,,,0,74,0,2329,[0A]0,,,,,,,0,77,0,2423,
18:20:48.906 -> 1 second timer for run
18:20:48.974 -> 1 second timer for run
18:20:49.178 -> GPS Availible!
18:20:49.178 -> 0,,,,,,,0,79,0,2489,
18:20:49.990 -> 1 second timer for run
18:20:50.193 -> GPS Availible!
18:20:50.193 -> 0,,,,,,,0,82,0,2583,
18:20:50.973 -> 1 second timer for run
18:20:51.177 -> GPS Availible!
18:20:51.177 -> 0,,,,,,,0,85,0,2675,
18:20:51.245 -> [58383] <[14|00|0B|00]Evw[00]1[00|0A]0,,,,,,,0,79,0,2489,[0A]0,,,,,,,0,82,0,2583,[0A]0,,,,,,,0,85,0,2675,[0A]
18:20:52.839 -> 1 second timer for run
18:20:52.976 -> 1 second timer for run
18:20:53.280 -> GPS Availible!
18:20:53.280 -> 0,,,,,,,0,89,0,2791,
18:20:53.998 -> 1 second timer for run
18:20:54.161 -> GPS Availible!
18:20:54.161 -> 0,,,,,,,0,92,0,2883,
18:20:54.973 -> 1 second timer for run
18:20:55.176 -> GPS Availible!
18:20:55.176 -> 0,,,,,,,0,95,0,2976,
18:20:55.990 -> 1 second timer for run
18:20:56.192 -> GPS Availible!
18:20:56.192 -> 0,,,,,,,0,98,0,3070,
18:20:56.226 -> [63378] <[14|00|0C|00]Evw[00]1[00]0,,,,,,,0,89,0,2791,[0A]0,,,,,,,0,92,0,2883,[0A]0,,,,,,,0,95,0,2976,[0A]0
18:20:57.819 -> 1 second timer for run
18:20:57.990 -> 1 second timer for run
18:20:58.262 -> GPS Availible!
18:20:58.262 -> 0,,,,,,,0,102,0,3185,
18:20:58.975 -> 1 second timer for run
18:20:59.179 -> GPS Availible!
18:20:59.179 -> 0,,,,,,,0,105,0,3278,
18:20:59.247 -> [66379] <[14|00|0D|00]Evw[00]1[00],,,,,,,0,98,0,3070,[0A]0,,,,,,,0,102,0,3185,[0A]0,,,,,,,0,105,0,3278,[0A]
18:21:01.009 -> 1 second timer for run
18:21:01.179 -> GPS Availible!
18:21:01.179 -> 0,,,,,,,0,107,0,3344,
18:21:01.993 -> 1 second timer for run
18:21:02.164 -> GPS Availible!
18:21:02.164 -> 0,,,,,,,0,110,0,3437,
18:21:02.977 -> 1 second timer for run
18:21:03.281 -> GPS Availible!
18:21:03.281 -> 0,,,,,,,0,115,0,3579,
18:21:03.349 -> [70477] <[14|00|0E|00]Evw[00]1[00]0,,,,,,,0,107,0,3344,[0A]0,,,,,,,0,110,0,3437,[0A]0,,,,,,,0,115,0,3579
18:21:04.977 -> 1 second timer for run
18:21:05.011 -> 1 second timer for run
18:21:05.181 -> GPS Availible!
18:21:05.181 -> 0,,,,,,,0,117,0,3645,
18:21:05.998 -> 1 second timer for run
18:21:06.167 -> GPS Availible!
18:21:06.167 -> 0,,,,,,,0,120,0,3738,
18:21:06.979 -> 1 second timer for run
18:21:07.183 -> GPS Availible!
18:21:07.183 -> 0,,,,,,,0,123,0,3832,
18:21:07.251 -> [74374] <[14|00|0F|00]Evw[00]1[00],[0A]0,,,,,,,0,117,0,3645,[0A]0,,,,,,,0,120,0,3738,[0A]0,,,,,,,0,123,0,38
18:21:08.914 -> 1 second timer for run
18:21:08.982 -> 1 second timer for run
18:21:09.186 -> GPS Availible!
18:21:09.186 -> 0,,,,,,,0,125,0,3898,
18:21:10.003 -> 1 second timer for run
18:21:10.037 -> [77175] <[06|00|10|00|00]
18:21:12.073 -> 1 second timer for run
18:21:12.176 -> GPS Availible!
18:21:12.176 -> 0,,,,,,,0,128,0,3991,
18:21:12.990 -> 1 second timer for run
18:21:13.295 -> GPS Availible!
18:21:13.295 -> 0,,,,,,,0,133,0,4157,
18:21:13.329 -> [80470] <[14|00|11|00]Evw[00]1[00]32,[0A]0,,,,,,,0,125,0,3898,[0A]0,,,,,,,0,128,0,3991,[0A]0,,,,,,,0,133,0,
18:21:15.263 -> 1 second timer for run
18:21:16.010 -> 1 second timer for run
18:21:16.180 -> GPS Availible!
18:21:16.180 -> 0,,,,,,,0,135,0,4223,
18:21:16.993 -> 1 second timer for run
18:21:17.027 -> [84175] <[06|00|12|00|00]
18:21:18.621 -> 1 second timer for run
18:21:18.996 -> 1 second timer for run
18:21:19.164 -> GPS Availible!
18:21:19.164 -> 0,,,,,,,0,138,0,4341,
18:21:20.011 -> 1 second timer for run
18:21:20.181 -> GPS Availible!
18:21:20.181 -> 0,,,,,,,0,141,0,4433,
18:21:20.247 -> [87363] <[14|00|13|00]Evw[00]1[00]4157,[0A]0,,,,,,,0,135,0,4223,[0A]0,,,,,,,0,138,0,4341,[0A]0,,,,,,,0,141,
18:21:21.876 -> 1 second timer for run
18:21:22.012 -> 1 second timer for run
18:21:22.183 -> GPS Availible!
18:21:22.183 -> 0,,,,,,,0,143,0,4499,
18:21:22.997 -> 1 second timer for run
18:21:23.268 -> GPS Availible!
18:21:23.268 -> 0,,,,,,,0,148,0,4641,
18:21:24.015 -> 1 second timer for run
18:21:24.049 -> [91176] <[06|00|14|00|00]
18:21:25.543 -> 1 second timer for run
18:21:26.017 -> 1 second timer for run
18:21:26.187 -> GPS Availible!
18:21:26.187 -> 0,,,,,,,0,151,0,4758,
18:21:26.220 -> [93359] <[14|00|15|00]Evw[00]1[00]0,4433,[0A]0,,,,,,,0,143,0,4499,[0A]0,,,,,,,0,148,0,4641,[0A]0,,,,,,,0,15
18:21:27.795 -> 1 second timer for run
18:21:27.998 -> 1 second timer for run
18:21:28.031 -> [95165] Heartbeat timeout: 95155, 17102, 91156
18:21:28.269 -> GPS Availible!
18:21:28.269 -> 0,,,,,,,0,155,0,4873,
18:21:29.014 -> 1 second timer for run
18:21:29.184 -> GPS Availible!
18:21:29.184 -> 0,,,,,,,0,158,0,4966,
18:21:29.997 -> 1 second timer for run
18:21:30.064 -> [97221] Connecting to blynk-cloud.com:80
18:22:45.317 -> 1 second timer for run
18:22:45.419 -> [172463] Connecting to blynk-cloud.com:80
18:22:46.811 -> [173879] <[1D|00|01|00] "Here is the Blynk device code"
Could you tell me how I can implement such interaction?
