Question / bug regrading integrating Wio Terminal use of TFT and Blynk.
If I test the printing of the ligt & sound values on the screen, everything works. If I add the printing to the bkynk example is not working anymore.
Any clues?
• Hardware model + communication type. Wio TErminal + WIFI
• Smartphone OS (iOS or Android) + version: 1.7.6
• Blynk server or local server: Blynk Cloud
• Blynk Library version 1.2.0
• Code in attach (without tokens)
ESP32, Arduino, Raspberry Pi and the likes over the Internet.
You can easily build mobile and web interfaces for any
Downloads, docs, tutorials: https://www.blynk.io
Sketch generator: https://examples.blynk.cc
Blynk community: https://community.blynk.cc
Follow us: https://www.fb.com/blynkapp
https://twitter.com/blynk_app
This example runs directly on Wio Terminal.
NOTE: This requires Wio Terminal Wi-Fi support package:
https://wiki.seeedstudio.com/Wio-Terminal-Network-Overview/
Please be sure to select the right Wio Terminal module
in the Tools -> Board menu!
// import tft library
#include "TFT_eSPI.h"
// create tft object
TFT_eSPI tft;
/* Fill in information from Blynk Device Info here */
#define BLYNK_TEMPLATE_ID "id"
#define BLYNK_TEMPLATE_NAME "name"
#define BLYNK_AUTH_TOKEN "token"
#include <rpcWiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleWioTerminal.h>
char ssid[] = "WIFI";
char pass[] = "PASW";
// https://docs.blynk.io/en/blynk.apps/widgets-app/button
BLYNK_WRITE(V1) // this command is listening when something is written to V1
if (pinValue == 1) {
// do something when button is pressed;
} else if (pinValue == 0) {
// do something when button is released;
Serial.print("V1 button value is: "); // printing value to serial monitor
Serial.println(pinValue);
tft.begin();
pinMode(WIO_LIGHT, INPUT);
pinMode(WIO_MIC, INPUT);
tft.setRotation(3);
tft.setTextColor(0x0);
tft.setTextSize(4);
tft.fillScreen(0xFFFF);
tft.drawString((String)(analogRead(WIO_LIGHT)), 100, 100);
tft.drawString((String)(analogRead(WIO_MIC)), 100, 160);
TFT_eSPI tft;
BlynkTimer timer; // Announcing the timer
#define BLYNK_TEMPLATE_ID "templae"
char ssid[] = "wifi";
char pass[] = "pasw";
void updateScreen() {
tft.setTextSize(4);
tft.begin();
tft.setRotation(3);
timer.setInterval(1000L, updateScreen); //timer will run every sec
timer.run(); // run timer every second
Template ID, name, and auth token must be at the top of your sketch. The first lines.
Moving the BlynkTimer class after the header files should solve the issue.
This is because the header files often contain important definitions that are needed by the classes and functions in your code. When you include the header files at the beginning of your code, the compiler will process those definitions first and use them to validate the code that follows.
If you define a class or function before the necessary headers are included, the compiler may not recognize the types or functions used in your code and throw an error. Moving the BlynkTimer class definition after the header files ensures that the necessary definitions are available before the class is defined, which allows the compiler to validate the code correctly.
